Hah. I made my wife a deal. She could have a chihuahua if she got rid of her cat. Best deal i ever made. Any dog is better than the best cat that ever lived.
Ok it's not my intake manifold or gasket, was trying again to find this whistling/hissing nd by accident leaned on the cath can hose and it stopped so that's where I been going crazy for 4 days
While this site was down for a Lil while I looked it up on one of the vette forums and it seems like I'm not the only one with the noise in the hose, but I didn't see anyone saying they have pressure coming out the intake like I have Is there anything I can do to to make it like it was? I've had the can for a couple months and nothing till now |
And when I rev the engine to about 1500-2000 you can hear it push air out of the intake then the car takes air in like normal |
From what I understand the intake manifold creates the vacuum and pulls the oil and everything around through the can, when I installed it I had no noise for the past couple months and now I have this hissing noise
I've checked the hoses and no leaks, pinched the inlet hose and it stops the noise, did I do something to cause this? Can I get it back to being quiet like it was when I first installed it? |
I have brake cleaner will that work the same? |
You can do the carb cleaner trick to narrow it down. Until then, i'd suggest taking the catch can out of the equation. Do you have the ability to take it back to stock?
As Axis said, take the can off and return it to stock, that will eliminate that being part of the equation. Check and possibly replace the hoses, check all the routings are correct and the clamps.
