Hey guys...what are your opinions on a good set of drag radials to get, I still have my stock rims and would like to get a set for the rear, and not sure what brand or type to go with.
:iono: |
Nope...just regular tires right now.
V8 bolt on help desk! Now available!!
Thanks. That's what I want to do, just run them on my stock rims since they are just sitting around. |
Run them at ~23\25lbs around town and them down to ~16psi at the track.
OK, the C6 Grand Sport comes with a dry sump oiling system for the LS3 stock, how difficult is that to retrofit to a non DSOS LS3 or is there an aftermarket DSOS that is better?
Yes, I am thinking of cracking the motor and if I am going to do it I am going to go whole hog so I am gathering ideas. T. |
I've thought about the GS dry sump system myself. I'm curious myself.
Sent from my DROID RAZR HD using Tapatalk |
Iirc, It needs a longer crank snout. Sorry fellas.
Tbone all you need is a good melling and a better oilpan for what you use it for. So cam I gonna get my hands on this cracking motor stuff? Hu? Hu? Can I? I will work for beer ( but not during installs) and concerts. Lol |
Which means changing the whole crank? Are there true benefits to going dry sump or as you say just changing to the Melling and a better oil pan would be just as good. I am guessing some sort of baffling type insert into the pan is what you are referring to.
Because if I had to change the crank that could mean changing out to something bigger right?? like Stroking it? Hmmmmmmm. I am also investigating oil coolers, trans coolers, bigger rad, gears, tru trac, and a few other tings...... T. |
Weeeeeeelllllllllllllllllllllllllllllll........... .. since I don't really have any gauges it has been a lot of this....
http://retiredinsamar.files.wordpres...himp.gif?w=640 ....which is why I am thinking if I am going to go forward I am going to to it right. I just came across this place http://www.drysump.com/corvpan.htm and spoke to Darren who says they can do it and have a whole system with stages from 1-4. Depending on how serious I want to get. I used the power of the GOOGOO to find them. Hemp would be so proud of me. T. |
Decisions, decisions. |
