Whipple Dyno Sheet, Stock Bottom End!
Mods are in sig this was done on 93octane and alky injection on a 3.5pulley...
http://i459.photobucket.com/albums/q...le93octane.jpg Sadly I just can't launch well enough with the power. Soon to have a new trans from RPM ;). Going to the track tonight to see if the extra 50whp sees a gain in et or trap. |
never mind mods aren't in sig... texas speed blower cam 229/236 with PRC cnc LS3 heads, ARH headers 1 7/8 3" dumps, 4" pipeline intake, RPM built tr6060, Spec twin disc, pfadt drag suspension, DSS 9" conversion 3.50 rear gear.
Boost pressure is around 10.68psi at the top of the pull.
NICE!!!this must be on Dyno Jet huh ?
nice! If you can, try and get of video of your run tonight.
If i was you i would lower your rpms .. i think 7200 is overspinning it on a stock bottom end..
It has been spun to 7400rpm in the past, and has been over 650whp since October of 2009....Time bomb probably. So far so good. I wouldn't recommend this to anyone else clearly.
I also have an LSX 418 at the machine shop as well.
