JusticePete |
05-01-2012 07:54 PM |
http://sphotos.xx.fbcdn.net/hphotos-...20687219_n.jpg
That is an OEM ZL1 rear coil on the left. The Pedders coil on the right is .6mm thicker wire. What is really interesting is that Chevrolet now has coil wrap in the same place on the ZL1 rear coils that Pedders has been using on our lowering coils since 2009. If I didn't know better I would say that both coils were made at Pedders. At this time, only the red coil on the right is made at Pedders :D
Why would you lower a car that is already incredibly fast in the turns as was clearly demonstrated at the Ring? Let me count the ways :headbang: How about just the highlights?
The fender gap and minimum road clearances used at GM for the Vette and ZL1 are aggressive for an OEM. As performance tuned as the ZL1 is, Pedders as an aftermarket company can do things GM won't do. Lowering the ZL1 just an inch will have the bottom of the front spoiler / fascia 4.5" off the ground. That is pretty low and it will scrape on a good range of driveways and speed bumps. The driver will have to use a very gentle approach angle to navigate them. A Pedders driver knows this and doesn't mind it. Most new car buyers would not tolerate it.
Lowering the car will lower the CG and improve handling. Raising the coil rates a bit will do the same. The MRC system will still measure and adjust the same 500 times per second. The MRC front struts on the Escalade and Denali respond very well to Pedders Lowering Coils. The CTS-V does the same with lowering coils. Expect your ZL1 to do it better.
Add a Pedders 32mm rear Z bar and adjustable 27mm front bar as upgrades to the 25mm front and 28mm rear bars on the ZL1 to wring a bit more out of the ZL1 in hard turns and hard launches. My guess is that the Camaro TEAM looked at very similar bars and bar ratios. They came to the conclusion that for all round use, for optimal customer satisfaction and longevity of the rear lower control arms and rear sway bar mounting points a 28mm solid bar was perfect. Pedders clients will not complain if they need new lower control arms at 75,000 miles because the droplink mounting area in the bottom of the arm is fatigued. Many OEM customers would complain if that happened at 150,000 miles. They also will never know just how well a 5th Gen can corner with the Pedders maxed out bars.
The Camaro TEAM upgraded the sub-frame bushes for 2012 and then again for the ZL1. Why did they stop where they stopped with the ZL1? They came to the conclusion that for all round use, for optimal customer satisfaction and longevity the denser hockey puck hard front sub-frame bushes were the limit. Pedders drivers want more. So we deliver it. Our EP1200 kit first the 2010 / 2011 5th Gen with some thin fingers on the ends of the bushes. Those fingers are removed for the ZL1, but we still install 95% of the EP1200 bush kit by weight.
http://a6.sphotos.ak.fbcdn.net/hphot...86284116_o.jpg
