Suspension ???
I have a 2010 SS I will be converting to the FE4+ rear suspension I got 1LE sways already and running a square set up with 275s. How would this set up work/function with ZL1 wheels and tire size. I understand the 1LE is setup for a squared setup not a staggered.
It'll work out great. The tires will be a bit stretched; especially in the rear though. I'd consider going 285 all the way around.
Best regards, Tyler 888-308-6007 |
Meant how will the ZL1 staggered wheel and Tire package work with 1LE sways since the 1LE is set up for a square setup????
It should work just fine. You'll have some understeer but unless you track the car it wont be a issue.
Best regards, Tyler 888-38-6007 |
Ok cool wanted to make sure there would be no adverse effect an I'm trying to stay somewhat stock only real thing I wanna do is replace bushings and RLCAs
