question: for the turbo crowd
Ok here goes. If I increase my displacement from a 376 to 418 cube, and also lower my compression to a 9.5 from a 10.7. Will I gain more power on the 9 psi I have..or lose power due to my compression being lowered?
you will wont make the same power at the same PSI if you lower the compression rate. You will have to up the boost. The experts should chime in shortly. Also make sure you get the right size turbo for 418ci so you don't have problems over spinning the turbos.
I have gt 3586 i believe. Its the ips twins with ceramic bb and they are mid sized, so I think I am good. However, I am a whee bit disappointed at what u just said. I want more not less of of course...thank you for the reply. I await the experts to come on board for guidance. PS my builder also told me this, that i would lose power..ugh..no BUENO ! :)
Lowering compression you will lose power unless you compensate by upping boost. As stated, make sure you have a big enough turbo, if not you will overspin and boom goes your turbo.
I'm running the same turbo kit with a 418. At 9psi I'm making over 800whp. I'd be surprised if you were running above that on a 376 block. Get a boost controller and crank it up. Since its a built block it can handle a lot more than your 376.
Going from a 10.7 to 9.5 CP will lower your power, but you also need lower compression if you want to up your boost in the future. |
It would be hard for anyone to tell you exactly.. Cam profile, piston design etc.. will all play a part in this. If it was mine and i was using the ls3 block I was just stay with the 376 cubes and save the money and have a happier motor for longer.
Hi Pryo...i got ya num unless u changed it. I might just buzz ya. I know I will have to boost higher. But I am glad you have the same set up Pyro. I am virtually copy catting you :) Hope I dont get you upset .lol My confusion is this. Even though I lost some compression. I upped the cubes. So I am supposed to get more torque at least in the bottom, and hence I can also increase my boost. Would I not get more power at the same psi over all ? If you are running 9 psi and get 800 rwhp, thats more power in my book. I am just getting 650 rwhp and thats with a cam also, with the stock ls3.
It would most likely make more power at the same psi with the increase in cubes but like JLE58 said other factors will come into play. In my opinion I'd be surprised if you made less at the same psi. At 9 psi on a low compression 418 your turbos will be moving more air then with the 376 to get to that same 9psi so I personally feel you would make more power. Are you doing heads also? That would make a big difference too.
In your case it is hard to know for sure since increasing the displacement from 376 to 418 cubes would add hp/tq but lowering the cr reduces power.
Lowering the cr reduces power but it allows you to run more boost given the same fuel. So if you are running 9psi now but are lowering the cr one full point. The lower cr would loose about 2% power(per 1 point cr) but you would be able to up up the boost 1-2 psi giving you an overall higher hp number. So since you are turbo'ed you should be gaining 20-30 hp per lb of boost. |
If you go from a 376 to a 418 with SAME CP, then you will be making more power....that makes sense if you are going NA, but if your upping the cubes and have twin turbos, you want to lower your CR, and will lose N/A power. those turbos will produce a ton of torque! you would not believe it. Trust me, with the kit IPS builds, your 418 will love it. Turbos produce massive amounts of torque (when i was detuned at 8psi, i made 750whp/810wtq at 4000rpms). I'm not sure on your engine producing more torque, really depends on what its built with, although going to a bigger engine will produce more torque overall. Have you looked at heads? I would recommend 12* 6-bolt heads. They flow amazing! |
Pyro the heads u are speaking of...these 12* heads..who makes them, and how much $$. I am running a texas speed block. So far all looks well. Wiseco turbo pistons, tools steel pins, and steel top rings. I have a callies compstar. The dragon is really for the all out race guy. I knows it is better but I think for my intent its money i can save. i wont be beating my car up often. I just like to press her down here and there. BTW your words on my hp out look are encouraging. I hope you are right in my case to. I have callies rods, and if u missed it i explained for cyber my head set up thus far.
oh i forgot I also arped everything, and got the arp stud head kit with ls9 gaskets as my setup.
