How much RWHP can the 1LE axles handle???
So I know the 1LE axles compared to the SS are stronger. but how much stronger!,
Anyone have an idea it tried anything to prove the resistance of the axles? |
How much power are you putting down?
The 1LE axles aren't much different than standard SS axles... The big difference is because of the bearing from the ZL1 to handle the heat/load from tracking the car the Inner CV is standard SS while the outer is ZL1 to fit the hub.
The Axle killer is typically wheel hop, followed by a launch on DR or slicks. With 620whp on street tires with no wheel hop you should be fine......but will be blazing the tires. If you upgrade axles your next week link will be the stock diff. With 620rwp, depending on what you have to/want to spend I would seriously look at the ZL1 Diff/Axles from GMPP or look at the Hammerhead with DTS axles....I think Drivetrain shop also just came out with a 9" for the Camaro?? None of the options are cheap. You may want to look in the drag race forum to see what guys are doing to upgrade.. Matt |
Thanks Matt. So I started doing something to get rid if the wheel hop. I ordered and already got the 1.Hotchkis max subframe brace 2. BMR trailing arms and bushings 3. Pfadt Solid Bushings rear craddle 4. Pfadt Tie rods and bushings 5. Pfadt Featherlight Coilovers( Only waiting for this to arrive) Do you think this will help with the wheel hop!? |
Differential bushings
Wheel alignment This question would get better coverage in the drag racing forum. Most 1LE owners do not drag race. |
