ASAP! How did you M6 Owners refill the Tranny fluid?
Just put the car up to do the tranny fluid swap, and saw the fill hole is in a tight spot. I know the RP bottle is not going to fit the tip into that hold and still be able to turn upside down to fill
Looking for some clever tips ASAP |
Buy a siphon pump! They work great! I bought a small pump that fits inside the oil bottle, screws on, then just put the tube inside the tranny and pump her in :) It's made exactly for that purpose.
And she was up on ramps, no lift. I als used RP - Kragen, O'Riely's or any auto parts store should have one... Good luck! EDIT: as a side note, when I did mine, I didn't have the oil pump, but what I did have was my brake siphon pump! Not the best, but it did get me through until I bought the correct one! :) |
$3 pump from WalMart. It is clear long plastic tube with rubber ball squeeze pump thingy in the middle.
Thanks guys, RP synchromax is what Ive had for about 2 months sitting in the garage, finally gonna do it today! LOL
A funnell and about 4 feet of rubber tubing. You can pour 4 quarts of fluid in there standing up next to the drivers side from the engine compartment. SUPER EASY! :D
Get the Mobil 1 Synthertic ATF Multi Vehicle Formula (Dexron 3) Your synchros will thank you for it.:thumbsup: -Mark. |
I remeber I was in a hurry one day and couldn't find my bottle pump. So i ran the hose into the trans and using a basketball needle adapter on my blow gun I pierced the bottom of the bottle and held it upside down. Done it this way several times since because its the fastest way I have found. Redneck efficiency!
I have a can similar to a weed sprayer that you pump up and pull the trigger
-Mark. |
