RX Catch Can Help
I've had the can for awhile now, but for some reason I am speculating if I have my connections setup incorrectly. Looking to C5 for some answers so I don't drive myself crazy :faint:
Attached is my bay, kind of messy at the moment, but I have steam cleaner so that's probably something I should do soon.... http://i40.tinypic.com/qohfmb.jpg http://i44.tinypic.com/2lxh4ra.jpg http://i43.tinypic.com/2ihbk7n.jpg |
On the can, the center port is going to the passenger side orifice and outside port is going to manifold.
Is it ok to have the top valves pointing straight like this? I do not use a engine cover. |
It is installed correctly. There is nothing wrong with the the way the catch can ports are facing. Mine are positioned almost identically.
Great, thanks!
Just make sure the check valves are operating correctly and not making any whining or other noise. As long as you are catching oil you should be good.
