Footwell lighting
Ok folks, I just completed adding blue Led lighting to the foot/floorboard area in the front of my camaro. I found that there is a connector under the passenger side kick panel. It is the closest one to the door jamb once you remove the kick panel. Simply squeeze (pinch) the 2 release tabs at the top and then the handle rotates up to disconnect the connector. The Grey wire (about the center of the connector) on the body side of the connector is the light fading wire. I tapped the LED light power wire to this wire and completed the ground to any suitable ground connection. Now the LED lights work exactly as the overhead light does. Fades on and off, comes on with door open off when closed etc. I will post some pics in a little while. Still doing some other mods that has my attention right now. It was very simple to get to and required no special tools or connectors.
Thanks for the headsup. I'm going to be installintg my footwell lighting here shortly and any tips/tricks are helpful.
Thanks! |
:needpics: |
Very cool! Just like the connector on the steering column that does the same thing! :) Great job! I just wired both my footwell lights to the 1 wire ;)
Any pics on the one under the kick panel or the one on the steering column? Also when lights to you guys use?
There is a thread or 2 on the one under the steering column - I'd have to search for it - look under DIY for footwell lighting. I'm using the AAC LED sticks. Work & look great! Both in Amber...
Search: Your friend. http://www.camaro5.com/forums/showthread.php?p=1224402 |
Thanks. Found it after I posted hehe. Was getting ready to go to bed so I was kinda lazy :(. Got up the energy to find it hehe. Even posted in the other thread before I seen your reply. Now off to bed because got work in 6 hours :(.
:needpics: |
http://www.camaro5.com/forums/pictur...ictureid=19130 http://www.camaro5.com/forums/pictur...ictureid=19128 http://www.camaro5.com/forums/pictur...ictureid=19127 |
So you did use the Flex Led?
Cheers K |
I am going to attempt this in the next few days.:happyanim: Hopefully it will work out.:iono: Did you tap into any fuses in the panel, and did you run a wire down from the Dome Light?:iono:
This will be helpful info. Thanks.:thumbsup: |
http://www.camaro5.com/forums/pictur...ictureid=19130 |
I'll take you up on that if I run into any problems.:iono:
If you think of any other tips please PM me, as it will be the next week or two before I can get this started. I am leaving town this weekend.:happyanim: |
Did you connect the two strips of LED in series or in parallel please.
Thanks |
