Need help
Kinda new to the performance mods but I plan on getting a turbonetics turbo solo high flow cats and a cam just wondering what else ill need hopping to get about high 500 or low 600 range also what kinda guuges do you prefer I know a boost gauge but what 2 other ones thanks right now I have a roto fab cai throttle body and muffler delete
Just grab an AGP kit, make 600+ with no other mods. No need for cam/cats/etc. 6-7psi will make >600, 9+ should make over 700. Cheaper, and better too.
Fuel pump and injectors Im sure.....
I have your kit. you will need injectors, zl1 pump and controller. drop the HF cats idea and just delete the cats (HF cats and boost don't do well). you will loose your rotofab, but you will need a air filter and bigger 7lb springs for your wastegates.
