Camaro Convertible Windscreen @ PFYC-PartsForYourCar
2011-2015 Camaro Convertible Windscreen
Although cruising in your Camaro convertible is always an enjoyable activity, the excessive wind noise at even low speeds can put a damper on your fun if you're trying to listen to music, talk on your phone, or have a conversation with a passenger. Combine the great styling of the Camaro SportBar with this Camaro Windscreen and enjoy a comfortable ride in your Camaro convertible. The Windscreen is designed to match the curves of the SportBar for a flawless appearance while greatly reducing wind noise and turbulence. http://www.pfyc.com/mm5/graphics/new/CAM11WD-W.jpg - Windscreens are made of a single piece mesh fabric in an aluminum frame; the mesh itself reduces turbulence, dramatically cutting noise level by 50% - The Windscreen rests on the rear trim panels BEHIND the CDC SportBar. Others rest in FRONT of the SportBar, risking damage to the bar. It is held in place with two adjustable quick-release straps as opposed to other models that use four straps, risking additional wear. - No modification is needed to the vehicle or SportBar! - When not in use the Windscreen can be quickly unbuckled, folded, and stored in the trunk in its protective storage bag (included). It also fits safely under the top and does not need to be removed when raising the top. - Featured with CDC's Carbon Fiber SportBar ***Does not impair rearward vision. ***Complies with all the safety regulations of the car manufacturers. More Fun, less wind with a Wind Deflector, the #1 convertible accessory! 2011 2012 2013 2014 2015 Camaro Convertible Windscreen |
http://www.pfyc.com/mm5/graphics/new/CAM11WD-W.jpg 2011 2012 2013 2014 2015 Camaro Convertible Windscreen |
:D
Thank You for shopping at https://www.pfyc.com/CAM11WD-W.html?
