New Lingenfelter 3.91 Gears!!
Dont know if its a repost but heres the link:
http://www.lingenfelter.com/mm5/merc...egory_Code=C61 I need a good excuse to tell the wife that the car needs better gears, maybe if I tell her that I will get better mileage ..:facepalm: JM |
How does this compare to the 4.11's for the manual transmission? Stronger/safer than the 4.11's?
-Funk |
Wow, $800 for gears. It pays to be the first to come out with something for a 5thgen.
LPE Ring & Pinion Specifications: - Designed to meet original equipment specifications - Manufactured by American Axle the original equipment gear supplier for Camaro SS - Gear material is a modified SAE 4320 steel alloy Quote:
JM |
for someone who is not current in gears tell me what does that mean? higher 1/4 times, faster 0-60, etc. what makes it special? how is it different than 3:73?
Well I'm too late because I just had 411 gears installed on mine, but I would have definitely tried the 3.91's if I would have waited a little longer. Those(3.91) are probably perfect for the street/track guy with 600-800 HP!! Will somebody please try them and post results!!
Wow I should have just bought a corvette
Wow, that looks like some good stuff ... Nice torque gain of 45-50 at the wheels and no ECM calibration for speedo on the LS3 ...
$800? :facepalm:
Still don't get the point. Use stock gears, and figure out how to get better low end torque and keep tires on the pavement. My tires spin in all gears and I don't even have an SC installed yet. So, still can't understand the whole point of paying all this cash for some gears.
I would think if you have an SC, all the top of the line suspension stuff, best wheels and tires and stock gears your a perfect driver, and could use some better low end speed then upgrade gears otherwise you don't need them. I'm only 475rwhp. and can't keep tires down on the pavement in 3rd. gear, so not sure whats' up with that, but I surely don't need any gears that's for sure. |
1 Attachment(s)
I'll keep everyone posted as to my first impressions as soon as they arrive. Here's a pic of my broken Richmond's: Attachment 235498 |
