WHY YOU DO THIS?
Hey all,
I hit the local drag strip tonight in my auto 2014 ZL1, First two passes were good (ptm 5, transmission in "m" for sport mode) On the third pass however, about 2 seconds after slamming the gas the throttle response was gone and it revved all the way up to the redline. My car was dead in the water, while limping off the track I put it back into the "D" position, it lunged hard and returned to normal operations. I made 5 passes afterwards with the shifter in "D" and aside from wheel spin all was well. Why the hell did my car do this? I always baby it and never abuse it.. |
Wouldn't have happened with a stick shift.
nanny state
Yeah sounds like you just blew the tires off it, hopefully that's the case.
I'm sure it wasn't wheel spin, in my opinion it almost felt like it missed it's shift but how can that happen in an auto?
I should probably mention that I didn't exactly loose throttle response, the car had stopped moving forward. As I feathered the throttle to get off the track it kept revving hard but didn't accelerate, almost as if it didn't have a transmission.
Really sounds like wheel spin...granted we weren't there. you would know better than us. but from your description that's what it sounds like.
But why would the car coast down to almost a stop just to keep revving at the redline when I would try to accelerate?
And not move until I put it back into "d"
I believe the OP could recognise wheel spin. I believe we have a tranny issue.
Probably because you always baby it. The poor car was in shock from being allowed to run free down the track.
I had wheel spin off the line, then it hooked up and THEN this happened.
snapped axle from wheel hop? just throwing ideas out
