08 Z06 clutch
A good friend of mine has a very lightly used clutch out of his 08 Z06. Is this a straight bolt in? He has all of the parts for it. Pressure plate etc. What else should I swap/change out when it's down? Throwout bearing, pilot bearing?
i believe z06 should work cause zr1 has more bolts...hopefully someone replies
Yeah I'm looking at the flywheel and it has 6 bolts like LS3.
It will work. It's the same clutch that's in the Camaro to begin with.
Sweet, thanks for the heads-up. Gonna be picking it up for 200.
Used clutch parts, good luck with that
I've looked it over. It only has 18k babied miles on it. It looks really new. I'll just get my flywheel resurfaced and replace the other ods and ends while I'm at it.
I've never heard of a lightly used Z06 clutch ;)
