abl
Ok, I got some door panels with the abl and connector on them. I have a 2011 1ss. Will there be a connector for me to hook up to and if so will the abl work? Thanks for any info.
I don't think so, but I could be wrong. I'll let 2SSRS give you the final word on that part. But if you don't have the plug you can still tap into the wiring. Just makes it a 3 or 4 step process instead of a 1 step process.
thanks for the input, maybe tomorrow i will start to remove the panels. I dont want to be cutting up wires to do it. I don't have abl now, so its not that big of a deal, was just wondering since the new panels have them.
I just got my ABL door panels put in the doors of my 1LT last night. I don't even have the plugs in my doors so I'm just going to tap into the yellow wire on the window controls for power and then the black for ground.
so even if i plugged the connectors in they will not work. I also heard that they would work if the dealer programed it. Is this correct.
just wanted to be sure i could have this done before i go taking off the door panels again. saw some camaros last night with the abl on and looked pretty good. i do have new door panels that have the abl. so are they on during the day and night and when do they go off.
The ABL is on whenever your headlights are on.
well got a hold of a dealer and he said they could program it, we will see in the morning.
