Understanding F/I in a 5th gen Camaro
I get it now. These are ballpark HP figures for a 5th gen Camaro.
Roots (Maggie, SLP, Edelbrock) best for target HP 500-700, best for street, bypass valve keeps IAT’s low in traffic, and bypass valve puts rotors free spin drawing little HP in traffic. Twin Screw (Whipple KB, Lysholm) best for target HP 600-850. Not sure if Whipple’s bypass is a full bypass or if the rotors are compressing recycled air. I know KB still compresses the recycled air causing IATs to spike in traffic. Centrifugal (ProCharger, Vortec/Paxton) Best for high stall autos setup for the fastest drag strip E.T. over 750 HP, little to no benefit on street. Turbos can be designed for 500-2000+, but work best without cats. I like the front mount turbonetics kit, but I worry about managing all of the hot side heat and the OEM’s do not run turbos post cats. Agree, disagree? Do I pass the test teacher? |
Disagree. I'm a roots guy, but to say that Centri's have little to no benefit on the street is just crazy talk. Fact of the matter is, with any supercharger kit you will have at least 500rwhp on tap under your foot. Just about all of these superchargers are good for up to 750-800rwhp. It's only when you really start digging into your wallet and pushing the boost that Centri's run away into the 900-1000+ range.
Disagree. Whoever gave you this info needs a junk punch. :D |
:laughabove:
Those are some vast over-generalizations there, some of which are completely wrong, and others sound like they're directly from a sales brochure.
Okay junk punch, watch out before I give you a piston slap
Let me try again. PD roots Edelbrock E-Force, low end torque king, great for low boost stock LS engines, great for the street. Cons: the long intake runners will start to be restrictive if you want to turn up the boost. Magnacharger, great starter supercharger, most versatile, widest operating range, great for the street. It will bolt right up to a stock LS motor and perform great. Proven 100k+ mile durability. If you want to add a big cam, heads, or stroke you can spin to 18,000 RPM. Cons: None, other than 800 HP is the top and a few oil leaks. Twin Screw Whipple, a little bigger than the first two. Need fuel upgrades from the start. Can make more power than first two with other engine mods. Lower IATs than first two while under boost. Cons: A little less efficient than first two under ~5000 RPM in low boost mostly stock applications. KB, For those who like sucking in the rear. Cons, heat soak in stop and go traffic, smaller support base. Lysholm, For those who want a Lysholm Pros: good belt rap. Cons: cannot spin as fast as Maggie, history not as strong as the others. Centrifugal Small Procharger, Vortech/Paxton. Great for those who want to upgrade later to a big Centri. Easier to hook at the strip. Can run a little more boost safely on a stock bottom end because the torque curve starts later. Simple Air-Air intercooler, do not have to mess with IC pumps. Lowest cost to start out. Easier to add alky meth systems. Separate belt so if you break a belt you can still drive home. Cons: narrower power band than PD. Centri owners are mental! You must be wired a little different to own a centri. If you have specific technical questions about centri it is tough to get answers. Big Procharger, Vortech/Paxton, drag strip king, can go into the thousands of HP. Easier to tune and run than turbo. Cons: will throw a belt if you let off too quickly. Turbo for those who want turbo(s) Cons for all of the above F/I over N/A heat soak. In road racing (20 min sessions) and stop and go traffic, watch for heat soak. Better? What did I miss? I know some would prefer the way a certain F/I sounds over another. For me I think they all sound great! |
:iono: :facepalm:
Not really. Still way over simplifying things. Big centris don't throw belts any more than any other setup. |
Didn't want to be too wordy. Could have said PD for the street, Centri for the strip.
What am I missing? Would love to get into more detail For example, how to understand this http://www.eaton.com/ecm/groups/publ.../ct_127899.gif http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_127899.gif If throwing belts is not the weak link for big centri then what is? How much power does it take to spin a centri before the boost comes in? (Engine RPM idle-3K) |
Do you even plan on boosting?
This "PD vs Centri" debate is becoming as stupid as "L99 vs LS3" debates.
Well craziness,lost,or opinionated ??? Pages and pages of it |
Thank you Vader SS for the feedback! Tell us how you really feel about the Maggie ;)
Yes S3XPather, I have been exploring three options as an over winter project. 1. Mast L99 stage 1 cam with a 50 shot 2. LS9 cam conversion plus supercharger 3. Lethal Injection’s 3rd circuit appeal cam, they don’t release the specs but they do say the lift and duration are so big the valves never actually close. It’s not an issue because I have access to two Procharger unreleased F.U.-2 blowers that can be 300% overdriven. Setup as twins with waste gates opening at 1 RPM over idle it will maintain full boost to redline. Direct injected at 30 Bar, the setup basically converts my piston style engine into a gas turbine. I like this option because I want to think it will be able to be driven on the street. I would consider a centri just trying to understand them better. I drive about 6000 miles per year on the street and I do not want a pig that gets less than 12 MPG. I also want to stay with a pump gas 91 octane tune. I would consider alky/meth unless they destroy my cats. Trying to decide which supercharger would be the most street friendly matched with a L99 plus LS9 cam conversion, LT headers w/ cats, and ZL-1 fuel pump. My driving style is tame on the street, rarely cross 4K RPM. At the track I push it to limit (Road race and 1/8 mile drags) Current Mod list, C.A.I. CAI, LT headers w/ cats, tune, lowering springs, 20x9 OEM wheels with NT-05 275-40 on all corners. Next up: sway bars. |
