about to do my retrofit...
got the Morimoto mini stage 3 H1 kit from TRS and RGB colorshift 2.0 halo + fogs kit from AAC...want to get started on this this week, and was wondering if anybody had any helpful tips?
should i expect to buy some more wiring, issues/difficulties others have had doing something this? i've tried to research as much as i could beforehand, but figured starting this thread specifically might help too. thanks in advance |
I was going to add halos to the foglights too...ran into a possible problem with getting them open. So far I haven't been able to find a thread saying exactly how ppl opened theirs.
Anybody got advice??:iono: |
Do you know where you're gonna put the control box? I put mine in front of the shifter where the 4 pack gauge was supposed to go if I had one. There's a hole in there already so no drilling had to be done. Make sure the halos are positioned in a U fashion where the cut area is on the top. I made the mistake of putting it in a n fashion and it doesn't look right. MAKE SURE YOU PUSH THE REFLECTOR BOWLS ALL THE WAY IN!!! I didn't use enough force on one side and the entire bowl is leaning forward and providing no useful light. As for the fog lights, I've read that people using a dremel with a circular saw bit and cut it opens. If your high beams don't work, you may have to swap some pins to make them work. Hopefully this helps! Sent from my iPhone using Tapatalk 2 |
well, i worked most of the evening on these, and got the projectors fitted and wired, and wound up putting the fog halos in the headlight around the bulbs with the larger halos for a double effect. altho the larger halos wind up having quite a bit cut off when the cover is on (seems like roughly 40% is covered) :( now, the real issue i was having tonight is when i went to test the projectors, i couldn't get either low or hi beams working. i verified my setup by the instructions, connected to the battery terminal, grounded via radiator bolts (need to double check that that's a good ground, but i think i read that someone had used that spot before), and i got nothing. when i flipped to hi, i could hear the solenoid activate, but no lights! blinkers were lit, but turn signals wouldn't activate (would work with hazards tho), i checked fuses and nothing was blown... i'm going to email TRS for some advice tonight, but if anybody reading has some suggestions i'd appreciate it. i'm trying to get the car back together in time for club meets this weekend! thanks in advance |
Edit: Make sure nothing is plugged in backwards. That would cause things to not turn on. Sent from my iPhone using Tapatalk 2 |
to open the foglights all you have to do is cut where the housing and lens meets with a tool such as a dremel. Its that simple. Just take your time and go all the way around till the lens disconnects from the foglight housing. can we see how you mounted the halos? i wanna see what you mean that 40% of it is cut off when the cover is put on. |
http://img.tapatalk.com/d/13/03/13/ujarenyq.jpg http://img.tapatalk.com/d/13/03/13/ububu5aq.jpg I agree with puertoricanfront on moving the knob all the way to the right. There's not enough power heading into the HIDs on auto during the day so the HIDs don't operate correctly. I usually turn them off. Sent from my iPhone using Tapatalk 2 |
Thanks for the replies everyone. Jmontalvo's pics look pretty close to what I was describing. I can live with that look for a while :)
I didn't know about the power issues, but I did try my knob in all the positions. Would it make a difference that I didn't reinstall my fogs yet after deciding not to put the halos in for now? I wouldn't think that would prevent my hids from lighting, but at this point I don't have any other guesses. I'm at work for a while longer today, but I'll post some more of what I did when I get home. Thanks again guys |
1 Attachment(s)
Hmm I've got ballast blue going to green, and ballast red going yellow...
Attachment 485095 |
Figured it out...wasn't getting a good ground on either from the radiator bolts. So, the lights work.
Thanks for the suggestions guys |
Anybody have any clue why my blinkers won't blink??? They light up, but when I try to activate left or right they just stay on. They'll blink when I activate the hazards, but that's it.
If it weren't for the eventual safety inspection I'd just leave it |
