SPARCO EVO II Race Seats
So I'm planning on changing my seats over to Sparco EVO II very soon but need help on what i need for installation and what to do with the Air Bag Sensors from the Stock Seats. I'm only 5'-9'' so height is not an issue for me even with a helmet.
Looking for some help. Anyone. :iono: |
I have sabelts. Needed side brackets from sabelt and the planted seat brackets. I am 6'2" and with sliders would hit headliner with my helmet....so no sliders for me and solid bolt to planted bracket. Planted brackets are all out of tolerance though and make seat loose, small hits on the front hooks fixes this or a small steel plate under them on front preloads them.
Your airbags will work but you will have a red light telling you something is missing and everytime you start you have to dismiss message. You can cheat driver seat with 2.8 ohm resistor....good luck cheating passenger seat....too complicated and still doesnt work all the time. |
1 Attachment(s)
I swapped my drivers seat for the Evo 2. I love the seat. I had to also fix mine directly. I'm 5'11" and I barley fit with a helment. If you install the sliders you will sit an inch or so higher.
I was planning on using the evo 2. I had to go with the omp wrc due to the location of the shoulder strap pass throughs. Apparently the sparcos are not designed for anyone over 6 feet. I'm 6"3. I was fitting for the seat at Atlanta Motorsports park. I couldn't be happier with the seats. I did go with the Xl which is equivalent to the evo 2. Very comfortable and looks great.
1 Attachment(s)
Sorry for the bad pictures. Please keep in mind the width of these seats also I bought the resistors I just decided not to use them. In living with the light in. However it is not a daily driver.
More
1 Attachment(s)
Another pic
1 more
1 Attachment(s)
Here you go
Talk to Jordan at JDP, those are the seats he runs. I'm sure he can help for sure on the getting the setup correct. Those may be in my future, but I want to have sliders with mine if possible. Jason. |
Thank you Kurt Robinson Aero Sport Concepts |
Marrad seats have bulging bottom, which gains an extra 1-2" even with the sliders. It's similar to Bride Vios III seats that I've used on my Miata, which are too small for this car.
I'd highly recommend you check out that seat. OMP and Sparco seats are nice, but they will not provide extra head room everyone seems to be hoping for. http://www.arizenracingsports.com/pr...sp?prod=MLX1LL I'm thinking about getting this for my 1LE, if only I can make sure I can figure out all sensors, etc; I hate service lights at the dash. |
