Coolingmist: Tune or no Tune?
I'm not sure if this question has been answered or not, but I currently have a supercharged camaro pushing 632RWHP at 9 pounds of boost. However, I'm really really interested in purchasing the coolingmist system STRICKLY for safety reasons. It's my understanding the best way would be to have my installer install it WITHOUT a tune that way my camaro WILL NOT depend on the Methonal system if it was to ever run low. Is this the CORRECT and ONLY way to avoid a dependency on methonal? :iono::iono:
Good question maybe someone will answer it instead of just looking at the thread.
I get the car dialed in first without the meth/alky injection, save that tune. Then I tune it for the injection.
You can buy a used hand held system used pretty cheap and have both tunes loaded to it, but must guys just leave the tuned with meth/alky injection in the car and carry extra. |
Tampa Tuning, thanks for the information I will install both tunes. But I do have one more question, if i use the meth injection without the tune, will that be considered too much octane during normal to moderate driving situations?
Whether to tune for meth spray or not depends on some other factors as well as the philosophical leaning of the owner. Clearly, the car should be properly tuned before the meth or meth/water is applied. Assuming the proportion of the spray is correct, you have the choice of utilizing the extra available octane to allow advancing the spark, or just having the spray as insurance against bad gas, 100 degree heat soaked days at the track, etc. Properly done, there will be a modest performance improvement even without tuning. The thing I most definitely do not recommend is using alcohol spray to prop up a fuel system that is maxxed out. Tuning for meth, makes you vulnerable to the additional points of failure introduced to the system. This is fine, as long as you go in with your eyes open, realizing that even a brief detonation event can be catastrophic with a forced induction motor.
9 PSI in my opinion it too much for 93 octane and the inconsistency of pump fuel from station to station or week to week. So Cooling Mist is a great option to protect your engine from Detonation. And you are Correct in that you can use it for a safety WITHOUT A SPECIFIC TUNE for those days when you get bad fuel or it is too hot for boost. I can help you with the Cooling Mist system and help you jet it and tune it to work with your set up. Ted. |
The last couple of times we tuned the car we were unfortunate to have bad gas but thats been a problem with a few gas stations here as of late, but I STRICTLY want it as insurance and not added HP. As stated earlier, if I just so happen to take my vehicle to the track I would definetly want to use it. I guess I'm starting to realize more and more that I WILL need it, therefore please send me a PM with pricing on the Coolingmist system preferably with a fender mount tank.:thumbup: |
I knew you would take the leap
Ted. |
after talking to ted this morning . i am a meth addict now,:D:D:headbang:..thanks for taking time out to call me ted.. nice to do business...a+ vendor here..soon as we get ready for install, i will have tyler from extreme perf call and get those tips and tricks ...knowledge is always a good thing...
