stuck on meth install
i'm stuck on my meth kit install because i can't get good signal to the controller. when i test the signal wire on the map i can only get .7 volts at idle and only see it shoot up to 1.6 v when i stab the throttle. my grounds are good, and so is the voltage to the controller. nothing that i google seems to help so, now i have to come here and ask around. any help?
got it working. turns out you just get way lower voltage signal when using a 3 bar map and only using 14 psi. she's now a squirter... no thanks to you bums.
You are entirely welcome. Give a man a fish, he becomes a liberal. Make a man catch a fish and he is a conservative for life.
