ksspeed |
08-08-2013 07:27 PM |
... So here is the answer! I spoke with someone on the forum, unsure if he wanted his name mentioned, but i owe him a big thank you. For anyone installing an MSD 8969 window switch, or equivalent, the switch should be set for "1" cylinder. The signal wire will connect to the third wire from the left (on a LFX at least) This is a different color wire on each cylinder harness, and the only wire on each harness that changes color. I spliced into a couple of different coil wires (all on the third wire from left) and had proper signal.
