Subwoofer and Amplifier install help
Subwoofer:
http://www.pioneerelectronics.com/PU...PRO/TS-W3003D4 Amplifier: http://www.pioneerelectronics.com/PU...eries/GM-D9601 Recently got both of these and installed them to the back of my trunk with the battery. I have an RCA cable and found out there are no plugs to plug them into behind the radio. So instead decided to install them to the 2 trunk subwoofers, but they don't seem to be giving enough power. I seem to be installing this system the wrong way can anyone help me out on how they did theres? And are there any wires that I am possibly missing to give more power? |
If you have the BA system, you can use the FARK harness (from ********). It will connect to the factory amp and provide the preamp outputs needed for connecting your amp.
when installing a amp, is it still necessary to go behind the stereo for the remote wire for the amp? I wanna put a sub in my car. it has the boston acoustics system but just not enough bass.
I believe there is also a signal wire in the BA system already present at the amp. Get the FARK harness from ********. Makes everything plug and play, so you won't have to alter any wiring. |
gotcha.............I just went to ********.com...........they have that T harness for $69.99...................plug in play
