Bracket Racing ZL1
Time to do a build thread.
2013 ZL1 #7860, A6, IOM, Coupe (LSA & 6L90E) Engine, Drivetrain and Cooling Modifications: Active Interchiller 18” Extreme Chiller, Ron Davis Heat Exchanger, Rotofab Intercooler Coolant Tank Rotofab Cold Air Intake, Rotofab Big Gulp Air Scoop, Rotofab Washer Fluid Relocate #2, Custom DRL Delete Air Intake Nick Williams (Boost Spec.) 102mm Throttle Body FasterProms Ported Blower (Base and Snout) (2.5 & 9.55 Pulley Combo) Metco 2.5” Upper Pulley with Custom Rip Cut, ATI Super Damper Lower Pulley Assembly, 9.55” Pulley, 67” 8 Rib Belt, Larger Idler Pulley Dynatech 2” Ceramic Coated Long Tube Headers with 3” Super Catalytic Converters Billy Boat 3” Dual Mode Exhaust with Custom 3” Connections (Full 3” Exhaust from Collectors Back) Injector Dynamics ID1300 Injectors, DSX Flex Fuel Sensor Kit, DSX Auxiliary Fuel Pump System (Activates at 7.5 PSI), 91 and E85 Fuel BTR Stage 3 Positive Displacement Blower Cam (Cam Motion Core) BTR .660 Lift Dual Valves Springs with Titanium Retainers, Keepers, Locks and Seals, GM 3 Bolt Cam Sprocket, Comp Cams LS Rocker Arm Trunnion Upgrade Circle D 3200 Stall Billet 285mm LSA 6 Bolt Torque Converter, TCI Flex Plate, Derale Remote Mount Transmission Cooler with Dual Fans, Transmission Dip Stick NGK BKR7EIX Spark Plugs Gapped at .040, Granatelli Spark Plug Wires Innovate Motorsports LC-2 Wide Band Sensor (Driver Side Bank, Pre-Cat) Other Modifications: HP Tuners VCM Suite Professional, SCT X4, Dashlogic OBDII Display Controller, Intercooler Coolant Temperature Sensor Apex Catch Can, Metco Oil Cap Breather with Custom JRE Check Valve RPM Chromoly 6 Point Roll Bar with Hydro Carbon Finish, Rear Seat Delete, Sparco Harnesses, Custom Harness Tank Plates, H3R Fire Extinguisher and Billet Bracket, Metco Drive Shaft Loop with Custom A6 ZL1 Bracket, SFI Rated Transmission Blanket, Biondo Bracket Racing Dial Board and Controller, Custom Console Switch Panel (Line Lock, Chiller, Fans and IC Pump), Hurst Line Lock with Switch Link Controller, Mickey Thompson 305/35/20 ET Street S/S Drag Radials, Zero Camber Rear Drag Race Custom Alignment, Detroit Speed Engine Mounts, Front Sway Bar Disconnected. |
Did your 60' improve with the custom alignment?
Your car and trailer look awesome; the attention to detail is what I expected!
Very nice! What kind of ets are you running?
the attention to detail is what I expected!http://www.deente.com/s/images/6.gif
