Hole on back of muffler
2 Attachment(s)
I'v been saying to myself all along that what I'm seeing coming out of the exhaust is condensation heat and cold air but can anyone tell me what the hole is for? Looks like a drain hole. And it's spotting the garage floor pretty regulary.
I'm sure it's normal but can anyone tell me where all the oily shean is coming from? .....:noidea::noidea: |
Hole is Normal, oil sheen not. Are you sure it's oil and not carbon?
Sent from my 2SS/RS |
Do you have a catch can?
...if you don't stand on it occcassionaly, and only run it a low speed carbon accumulates in the exhaust system. Blowing out the buildup once in awhile will eliminate this stain on your floor.
2 Attachment(s)
Thanks all for quick imput......:happy0180:
...no, the catch can will eliminate the oil ingestation into the super charger and intake manifold. The oil buildup will degrade your engine performance over time, but not lead to a stain in the water condensation dropping to the floor during normal warm up.
did you remove your catalytic converters? Also does the car have a tune in it perhaps?
..it's carbon buildup in the factory exhaust system....it's need to not idle so much, not be be thought of like a passenger vehicle, or babied. It will build up and accumulate carbon over time unless one stands on it and blows it out of the system. That, or it's throwing a CEL for running rich.
This is a drain hole for water
