OEM GM wheel lock kit - PN?
Making sure I am ordering the correct wheel lock kit for our car from GM. Is part number 19259109 the correct fit our 1LE wheels?
Thanks! |
This is the kit I am getting instead.
http://www.apex-speed.com/gorilla-wh...1.5-black.html It's cheaper than the one from GM and 20 wheel locks total instead of just 1 per wheel for the $90 GM kit. The other kit from GM is $150 and still only has 4 wheel locks and 16 regular lug nuts. Plus the kit I linked the lug nuts are black. |
Actually, after giving it some thought, I am going to go with those locks. I figure 5 wheel per wheel is better than 1. And it's cheaper. I am keeping the stock chrome, however. I know, I know, the black does look better. But trying to keep it stock in appearance....
There is another kit then that has chrome lugnuts then that you can use instead.
http://www.apex-speed.com/gorilla-wh...4mm-x-1.5.html Both I think will look great with your 1LE. |
