Procharger F1-R
If anyone is looking to go with a Procharger F1-R, I can give you all the info you need on install and its capabilities. It is rated for 38psi and 1300hp capable. I am a huge fan of Procharger and their winning history is unmatched. My car was putting down 1000rwhp with the F1-R.
The hot new setup is the Procharger F1-X. Procharger recently re-rated it's lineup....
:confused0068: |
F1-x sounds nasty!
If you go by inlet and outlet size...the X looks bigger and badder....but the cfm rating on the 2 is still showing as higher. Ron is at PRI and they are telling him the 1X is the top of the heap. ProCharger F-1X Base HP Range of NA Engine: 375-550 HP Maximum Supercharged HP Rating: 1,300 HP Maximum Airflow: 2,000 cfm Maximum Boost: 38 psi Inlet Diameterw: 5 inches Outlet Diameter: 3.5 inches Maximum Impeller RPM: 72,000 Internal Step-up Ratio: 5.40:1 Self-Contained Oiling: Yes Reverse Rotation Available: Yes ProCharger F-2 Base HP Range of NA Engine: 425-600 HP Maximum Supercharged HP Rating: 1,600 HP Maximum Airflow: 2,700 cfm Maximum Boost: 38 psi Inlet Diameter: 4.5 inches Outlet Diameter: 3.5 inches Maximum Impeller RPM: 65,000 Internal Step-up Ratio: 5.40:1 Self-Contained Oiling: Yes Reverse Rotation Available: Yes |
http://www.procharger.com/supercharger/blog/?p=321
What about the new f3??? ProCharger F-3A-121 Base HP Range of NA Engine: 500 – 850 HP Maximum Supercharged HP Rating: 2,100 HP Maximum Airflow: 3,100 cfm Maximum Boost: 40 psi Inlet Diameter: 5.5 inches Outlet Diameter: 4 inches Maximum Impeller RPM: 72,000 Internal Step-up Ratio: 6.24:1 Self-Contained Oiling: Yes Reverse Rotation Available: Yes ProCharger F-3R-130 Base HP Range of NA Engine: 600 – 900 HP Maximum Supercharged HP Rating: 2,600 HP Maximum Airflow: 3,600 cfm Maximum Boost: 45 psi Inlet Diameter: 6 inches Outlet Diameter: 4 inches Maximum Impeller RPM: 72,000 Internal Step-up Ratio: 5.63:1 Self-Contained Oiling: Yes Reverse Rotation Available: Yes ProCharger F-3R-136 Base HP Range of NA Engine: 700 – 1,000 HP Maximum Supercharged HP Rating: 3,000+ HP Maximum Airflow: 4,000 cfm Maximum Boost: 50 psi Inlet Diameter: 6 inches Outlet Diameter: 4 inches Maximum Impeller RPM: 72,000 Internal Step-up Ratio: 5.63:1 Self-Contained Oiling: Yes Reverse Rotation Available: Yes |
Better have one hell of a crank for a f3
Any of the F series are monsters.....but the F3 is too big for a street car....you would need a monster motor to take advantage of these...I would think.
I am going with either an F2 or an F1-x depending on what Ron comes back with from PRI and either one is simply ridiculous. I am going to have a 434 cubic inch engine and I am concerned that even that will be big enough. |
I am going to a F2 as the F1-R is too small for my motor is what we are being told by Procharger. The motor has too much base hp for the F1-R to build boost and they recommend the F2 for my application. HufferSS you go with the X and I will go with the F2 and we will see which one actually performs better.
It might end up that way....we'll have to see. Like I said...either are absolute animals and it's weird that the inlet on the F2 is smaller than the inlet on the X but it's rated for more power. Hmmmmm. |
I want one that has the loudest whistling sound
