Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (http://www.camaro5.com/forums/index.php)
-   Camaro DIY & HOW-TO instructions & discussions (http://www.camaro5.com/forums/forumdisplay.php?f=67)
-   -   DIY Installing front speakers LOTS OF PICS (http://www.camaro5.com/forums/showthread.php?t=130857)
Chris-10 09-04-2013 02:55 PM
Amplifiers provide the electrical pressure in a circuit; ohms measure the resistance, or load, against that pressure; and watts measure how much power is released as work. So, using one of those math formulas, an amplifier that provides 100 watts of power through a 4-ohm speaker, will produce 200 watts through a 2-ohm speaker, because it's easier to push that reduced load.
Chris-10 09-04-2013 02:57 PM
I think that's the reason, gotta love google!
If you don't change out the rear speakers you can adjust the fade on the radio or if you changed out the amp you can adjust the gain. Changing the amp out is the BIGGEST improvement you can do with the BA system.
Meister 09-04-2013 03:22 PM
I've already added the JL XD700/5 amp so I do have the gain controls. I will adjust on those too. I think my head is spinning now from that electrical lesson - lol:eyebulge:. It's great to have help so readily available. Thank you again!
Chris-10 09-04-2013 03:58 PM
No problem Mike, anytime! Just paying it forward.... I've gotten a ton of info and help off this site.
kidd79 11-09-2013 01:36 PM
Thanks for this!! Very Helpful!!
Camaroshark 12-09-2013 02:29 AM
Thank you for the write up. It was a big help. I did my fronts and installed the JL C2-650 components set this weekend.
They sound fantastic. Next week I think I may tackle the rears. I have the JL C2-690 6x9s for the rears.
Again... Very valuable writeup. It should be a sticky!
Torba 01-13-2014 07:29 PM
did you build the wood piece that hold the new subwoffer?
mydreamcar 09-29-2014 03:14 PM
sub
Tonydig11 11-11-2015 03:40 PM
Old post but followed it today while doing my 2ls. Thanks for the post
Installed Alpine SPS-610C with Merta adapters. Tweeters needed a little hot glue but fit right in the factory pods
kiteman 04-26-2016 04:16 PM
Originally Posted by Meister (Post 6977609)
Didn't sound like much bass was coming out of the new speaker. Did you notice that you had to turn up the front fade or overall volume after your install? Any thoughts? Thanks!
The reason stock speakers are louder is because their sensitivity is very, very high, so in general they will get louder at any given volume level. It'd be difficult to find speakers aftermarket that have their efficiency.
Also thanks for the write up. Please do us all a favor OP and don't remove the pics from wherever they are stored!! I hate it when that happens!!
