whats the issue with FI on these new v6's?
I have been thinking about getting a new v6 and Turbocharging it so i will have twins, but I keep reading about this fueling issue, however i can't any info on what the problem is.
can someone point me to a better explanation of it? |
my car runs about 45 and 60 under boost I do have 2 pumps in the tank to keep up though lol |
so it runs booth and in-tank, witch feeds the high pressure, then the high pressure bumps it(psi) up? that seems redundant to me....... no ownder there are issue. i assume the injectors need this to fire because they are Di-erect injection? |
is there any other company that makes a high pressure pump that could be fabbed/retrofit to work? |
This is an example of our stock HPFP.
RPM x Fuel Pressure. RPM FRP_C psi 2599 1055.87 2798 1421.37 3047 1575.11 3047 1575.11 3214 1659.23 3544 1694.04 3749 1714.35 4147 1699.84 4354 1705.64 4771 1708.54 4955 1705.64 5399 1720.15 5589 1734.65 5994 1723.05 5994 1723.05 6364 1723.05 6531 1721.6 6727 1801.37 6126 2021.83 5095 2036.33 4628 2063.89 3760 2076.94 3409 2097.25 2843 2107.4 2586 2121.9 2586 2121.9 2076 2140.76 1583 2148.01 1362 2121.9 1240 2043.58 1187 1884.04 1136 1789.77 1124 1596.87 1073 1504.04 1042 1318.39 997 1237.17 997 1237.17 968 1070.38 929 994.96 918 841.22 |
Yeah, exactly what we are seeing. We get a sharp drop at about 6100-6200 RPM and it goes lean. It should steadily increase, just at a slower rate after peak torque.
http://www.google.com/products/catal...d=0CLEBEPMCMAo |
That does not appear to be the one....the one we are sourcing has 3600 PSI peak and feeds a 2012 v8 twin turbo production car.
