Destructo09 |
03-30-2015 03:35 PM |
They are more firm than OEM, the biggest downside though so far is, make sure your careful if you run bigger tires up front. 275/40R20s will most likely not work with them unless they've been worn down some. From what I can tell the spring perch is about 5mm closer to the tire then the OEM struts which was just enough to make a new set of 275/40s rub on the strut.
I did my first autocross on some STR.T shocks/struts this past weekend, and not really sure I could tell any major difference between the OEMs and these.
