engine is finally getting built !!!!
3 Attachment(s)
finally got my new one off carrillo rods and my engine is getting built. i should be able to drop it in the car this weekend.:thumbup: i also got a 44mm precision wastegate to put in.
I also have the STS system, along with meth and nitrous. I haw noticed a large boost creep issue when staying on it for a long period of time. Do you expect the larger wastegate to solve that issue? If so where can I get one and does it go in the same location as the old one just before the driver side exhaust tip?
Very nice! You'll love that wastegate. How does the weight of the new rods compare to stock?
looks good :thumb: are you doing the extra injectors like grethen? he has been a big help to me in getting mine set up.
I'm gonna turn my x pipe into a y pipe and put the wastegate closer to the turbo and then route it to the other exhaust tip. I have already ordered the aluminum fuel plate and ill figure out how I'm gonna run it once I get the car running. The new rods are a bit lighter than the old ones and definitely a lot stronger.
Good news!
More V6 Powa!! |
Sweet!
Sent from my GT-N8013 using Tapatalk |
