Missing MAF?
Well I need some help here because as it would turn out the 1994 V6 3.4L Chevy Camaro I am driving doesn't require a MAF and in fact doesn't have one by default however I have found what seems to be a MAF connection. The previous owner installed this intake system with some cheap PVC and a k&n filter but why the connection? Was this supposed to be swapped out for the V8?
http://i.imgur.com/lospMIb.jpg |
Go to a local pick and pull yard get yourself the correct stock intake and lid and return it back to stock. No way would I be running that.
Are you sure its a MAF connection and not an intake air temp connection?
Edit: never mind. In you picture it looks like I can see an intake air temp sensor on the elbow. |
