ZL1 torque specs
I've google searched endlessly but cannot find:
Torque spec for the Front Caliper cross pin that helps hold brake pads in (1 bolt per front caliper) and I believe it's a 13mm bolt. Also what are the torque specs for the caliper brake fluid bleed nipples for the front calipers and what would be the torque specs for the caliper brake fluid bleed nipples for the rear calipers |
