Anyone running Schroth Rallye 3 with Recaros?
I've seen a few threads where members were going to install a set on the base seat with headrest causing some issues. Has anyone used these on the Recaros, though? It appears that it would be a better fit with the harness guides that are in the seats.
I was able to pull the harness through those small belt holes by the headrest, but I literally had to yank on them. There's a regular seat belt receptor on the harness that comes with a padding. I had to cut that padding to get it through.
https://lh5.googleusercontent.com/-n...417_234306.jpg |
I think I got mine from Evasive motorsports. It was the cheapest seller at the time of my purchase. |
I finally got the full powered version, and it gave me back the 1" lost with the manual seat!
https://lh5.googleusercontent.com/-1...529_000848.jpg I attached the Schroth to C pillar top belt anchor, seat belt anchor by the door, and finally to the seat belt receptor bolt on the seat, exactly as described by the harness instructions. It seems to work great. Of course, I'll have to try it at the track for the final verdict. |
Hey thanks for responding X.... hadn't checked this thread in a while...LOL
X25 is there the ability to disconnect the belt from the C pillar without unbolting it? Like a quick disconnect if someone is actually in the back seat? I saw a reference to that on Schroth's site. Any chance you could take a pic where it's connected to the C pillar? I couldn't find any other pics besides your setup here. Very curious to read how it works for you.
FYI, you'll have to install these harnesses on both sides for track time, autocross might not matter, that likely depends on the club. For HPDE though only a harness on one side would fail tech if you need an instructor to ride with you.
