Service Stabilitrak and Flashing CEL
I have 45k miles on my lfx v6 Camaro and today for the second time in the past two months my car started shaking when coming down to idle. While it was shaking I got a flashing CEL and a service stabilitrak message. I was just wondering why its this is happening and how can I prevent it? Maybe a misfire? Start by changing out all the spark plugs? Both times this happened I just restarted my car and everything was fine, like it never even happened. Ever since day one, ive only used full synthetic mobil 1 oil, and nothing less than 93 octane since ive owned the car. I also have been using a catch can since the car was bought new. just wondering what steps I should take going forward. this same problem actually just happened to my neighbor today too so we could use the help. thanks
Don't spend money changing anything until you know what the diagnostic codes are. Call On Star or see your dealer.
BTW, why are you using 93 octane in a V6? It is of no benefit. |
A p0300 only indicated the PCM has detected a misfire but not which specific cylinder/s. If you can get a misfire count for all cylinders you could locate which one/s have the highest count and go from there. Being a v6 I would suspect a coil given your description, but don't change any parts until you can be certain you are changing the correct part. Often on the 3.6 you'll get a misfire from a coil under certain conditions which can be hard to duplicate.
Check the spark plugs. Same thing happened to my ss 3 times in 1 year due to a loose plug.
