Eibach Sways
What settings are most using??? examples of how ride feels with settings...
I used the middle option for the rear bar and the softer for the front(Option A in the instruction guide). Are you installing them yourself?
im thinking about it, but i know you have to do a wheel alignment after install, so i have a performance shop that im good friends with so i may have them just install the springs and sways and do the alignment, is there an instructional book that comes with this set up, that tells you which holes does what???
yes, there is a photo somewhere on these boards. it basically explains the results when selecting a setting.
The instructions that come with the bars tell what each setting is best for whether wet roads, track use, daily driver, etc. |
