17 inch VMS drag wheels TIGHT fit
I put my 17x10 vms drag wheels on and it is so close to the calipers.
Less that a zip tie..lol I will be drag racing so spacers are out of the question but has anyone had any issue with caliper rub? I've read all over they fit, never seen anyone mention how close..lol Tyty |
I run a 5mm hub centric spacer on mine. I did swap out the wheel studs to ARP's while I was at it. After that I swapped to a 15" conversion brake kit and still run the hub centric spacers.
I run a 3mm hub centric spacer on mine.
Were you able to use the VMS with the tight fit?
