Moderator
LLT Engine Internals Build
The LLT-powered Camaros have hit several bumps in the road to high-performance. From vendors backing out of projects to tuning woes, we are not where we want to be on the forced induction front.
It will happen eventually. In the meantime, we should compile some build options. I am not familiar enough with the engine internals of the LLT to do this alone, so let's get together and help a few members build up their LLT powerplants. Please contribute any aftermarket parts that will help our forced induction guys build their engines.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
![]() Drives: RY 2LT/RS Join Date: Jul 2009
Airaid Intake And Solo CatBack Solo Highflow Cats |
having FUN now 13.66@101
subscribed
I refuse to go smurfy
Drives: 2009 Challenger SRT8, 2010 Camaro Join Date: Nov 2009
Looks to be around $1k for a engine pulled from a traverse/arcadia/cts, getting one of those to a reputable engine performance shop to tear down and learn specs on it would be the best bet for finding out if there are any kind of real options already in place (rods/pistons) and if anybody has the ability to create a crank as a stroker....if the block has enough wall to handle a reasonable bore. So would a LLT community shop be willing to take that 1K hit, or could you find enough members to chip in on a purchase like that? My guess is no, it kinda sucked absorbing the $$ for a used set of heads on my own to try something nobody else has done....might gain squat, might make nice gains....if I do, then I'm sure I'll be able to sell my stock heads to somebody, otherwise, its money out the window I'll never get back. nervous!!
![]() -Bill...the Camaro was my wifes, now she's got a minivan Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
I have heard the stock engine internals are good for 650 HP. This was from supposedly a GM engineer. I have read elsewere that the LLT already has a forged crank, sinctered rods and beefy main journals. That said...
The torque rating for the tranny seems to be the limiting factor at some 430 ftlbs. The torque management system will help soften the shifts and reduce shock loads to some extent but, for the strip, that's not such a good thing. For my intended use, road course stuff, it should be OK. We'll have to keep an eye on the diffy as well. The guys running NO2 and DRs will give us a pretty good read on that. Any of you guys looked at your axle seals lately?
#6 |
Subscribing to this one....
#7 | |
GM HIGH-TECH performance Feb. 2009 edition. yes on the crank, rods and journals. Tried to upload the article, but not having luck.
#8 | |
Moderator
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS Join Date: Sep 2009
hopefully some info comes our way in time. suscribed.
2010 Summit White Camaro LS / M6 MRT V2.0 ![]() |
#10 |
Camaro➎ moderator
![]() MATERIALS Block: Sand cast aluminum (319) with cast in iron bore liners Cylinder head: Cast aluminum ( 319 semi permanent mold ) Intake manifold: Aluminum ( 319 Upper, and Lower ) Exhaust manifold: High-silicon moly cast iron Main bearing caps: Sintered steel ( CU infiltrated ) Crankshaft: Forged steel ( 1038 V ) Camshaft: Cast nodular iron Connecting rods: Sinter forged steel Additional features: Four-cam continuously variable cam phasing Internal exhaust gas recirculation ( EGR ) Pressure-actuated piston cooling jets Torque-based engine management system Secondary throat cut inlet ports Direct injection fuel system High-pressure, engine-driven fuel pump with stainless steel fuel rails Internal front cover damper plates Cartridge style oil filter Extended life spark plugs Extended life coolant Extended life accessory drive belts 7.7mm IT chain system for all HFV6 applications Coil-on-plug ignition Structural cast-aluminum oil pan with steel baffles 5W30 GF4 Mineral Oil Synthetic Oil for Cadillac applications |
#11 | |
Moderator
#12 |
Camaro➎ moderator
Just letting you know what you have to work with. It's a start
#13 |
dirtbag
Drives: 2010 camaro LS Join Date: Mar 2010
as of right now there isnt much, anything you would want you would have to have it custom made.....i have been looking at some custom cams(a big maybe) and a custom intakemanifold. but still its nice to see a thread about something other than intakes and exhaust!
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
I doubt we'll be seeing anything reasonable for cams anytime soon since we have 4 cams. would likely be too expensive.
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 06:58 PM |
| LLT engine specifications | Tran | Wiki | 2 | 03-29-2010 11:06 AM |
| GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 02:56 PM |
| L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 12:40 PM |
| GM moves closer to HCCI engine production | Scotsman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-16-2008 07:16 PM |
