Old 11-19-2014, 11:10 AM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
160 Degree thermostat
I have a CAI, Headers with cats, and a tune. My car is an Auto and I dyno'd at 541 RWHP. My ENG temp usually runs at 196 degrees during normal driving. Would I gain anything by putting in a 160 degree thermostat? I see where people are putting these in. What does your ENG temp run at during normal driving?
tnspd is offline   Reply With Quote
Old 11-19-2014, 11:16 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Unlikely you will see any advantages.
GM says min operating temp is 185 hence the 185 stat.
Oil companies state additive packages don't become active until 185 degrees oil temp.
The fans settings will have more affect on operating temp than a thermostat
The thermostat only sets the lowest operating temp
You will burn more gas because of longer warm up times and induce added wear on your engine due to longer warm ups.
Hope this helps.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-19-2014, 11:21 AM   #3
tnspd
tnspd's Avatar
Thanks Ted....I really did not see a need for it but was just wondering if my thinking was wrong and everyone knew something I was not in the loop on.
Old 11-19-2014, 11:23 PM   #4
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
I was wondering about the same thing on the 160 thermo. Thanks for the info.
Red Jewel RS is offline   Reply With Quote
Old 11-20-2014, 10:05 AM   #5
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
I think it might provide a bit of an advantage at the strip. It should lower engine bay temps lowering iats.
Trackman is offline   Reply With Quote
Old 11-20-2014, 10:07 AM   #6
JANNETTYRACING
Agreed but most don't go to the track Like you, Awesome numbers
Old 03-03-2015, 11:36 AM   #7
kgendron71
REDHOT_ZL1
kgendron71's Avatar
Drives: 2014 Red Hot ZL1 M6
Sorry for digging up an old thread but it beats starting a new one. :wink:
I was wondering the same reguarding the 165 thermostat. Why does it seem to be included in all hop up kits? Living in Florida, Is the lower thermostat better/worse for my car?
Thanks,
Ken
kgendron71 is offline   Reply With Quote
Old 03-03-2015, 06:51 PM   #8
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Thanks,
Ken
Here is the answer that Ted pretty much gave. The higher temps are better for you car as long as the car does not overheat. Higher engine temps give better fuel economy and actually a little less wear as long as your engine stays in that 195 to 225 range.
The reason most shops alter the thermostat in their kits is because the cooling system in the car is only designed to keep the car cool with stock horsepower. And that cooling range is pretty small. If you add a bunch of power you add a lot of heat and if you don't start cooling until the car is almost 200 degrees then it is pretty easy for an upgraded engine to blow through the stock cooling systems capacity to keep up.
No tuning shop wants to build your car power up and then have you come back and say, it has more power but everytime I put it on the track or drive it hard it over heats. The easiest way to improve your cooling system is to give it a head start and get it to go into full cool mode at 165 degrees. This makes a huge difference if your car ever gets close to running hot. 165 is not a bad temp, it is not quite as efficient as 195 but nothing like 100 degrees.
If I had no intention of racing my car ever,... the 195 t-stat should be fine. If you ever do race your car in any type of event then I would switch to 165.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 03-03-2015, 07:57 PM   #9
dcpatters
Drives: 2015 Camaro SS 1LE
With a 160 thermostat the engine still runs in the ~180 range. Some tuners recommend a cooler thermostat for consistency, when running leaner and more timing.
dcpatters is offline   Reply With Quote
Old 03-03-2015, 10:53 PM   #10
kgendron71
REDHOT_ZL1
kgendron71's Avatar
ty
Old 03-04-2015, 07:01 AM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
GM must have rethought this in the Z/28 as my car runs 172-176 at cruise and my ZL1 with a "160" thermostat runs at 178-180.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-04-2015, 07:55 AM   #12
MA2010SS
Drives: 2010 Camaro SS
My car runs at 188 when stuck in traffic for extended periods of time with a 160* but moving along it's around 177* The cooler it runs the less chance timing will be pulled and less chance of detonation. No issues whatsoever running it, hope that helps
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 03-04-2015, 09:02 AM   #13
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
I have a 160 stat. Oil temp runs just over 200 all the time. That's what I care about. But the fans don't kick on soon enough so my trams temps are a little high. Going to add a bigger or additional cooler
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 03-04-2015, 09:31 AM   #14
Trackman
Trackman's Avatar
Interesting
What oil does that motor call for?
