Old 03-20-2015, 05:33 PM   #127
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Originally Posted by Ron71 View Post
Nice clean install. What did you use for the rubber 90 degree pieces and where did you purchase them? Do you have a part number for the 90s?
Did you have to drill a hole in the engine cover?
Thanks,
Ron
Thanks. The 90s I just went to my local auto parts store and picked them up In the "help" section. Already tossed the packaging and receipts so no part number. I did not need to drill in the cover but I wanted to just for a different look. I also drilled into the top of the Throttle Body to install that fastener that holds the tube. Not for the faint of heart. Measure the depth about 4 tires and drill . It has a Christmas tree style faster that is pushed into place
Old 03-20-2015, 05:43 PM   #128
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
At JBA, right now. Yes, real Mexico. Tijuana.
CreeperRS is offline   Reply With Quote
Old 03-21-2015, 09:23 AM   #129
ForcFed93
Drives: 2001 2500HD
Results?
2001 ECSB 2500HD
ForcFed93 is offline   Reply With Quote
Old 03-21-2015, 10:05 AM   #130
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Lets us know the details and take pictures!! Or video
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 03-21-2015, 11:01 AM   #131
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Maybe you can tell which one from this link? (HELP products from Dorman):
http://www.finddormanhelp.com/Search?q=elbow
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 03-21-2015, 05:26 PM   #132
Mikamaro
MikeNoMaro
Mikamaro's Avatar
So??
Old 03-21-2015, 06:36 PM   #133
dcpatters
Drives: 2015 Camaro SS 1LE
Originally Posted by Nick S View Post
An important note though since your dyno run will likely be done at full throttle the ECM will ignore fuel trims anyhow so I'm not sure what good it does to log fuel trims at WOT. At WOT the car goes into open loop anyhow with fuel enrichment. The wideband O2 sensor would be the most valuable tool for monitoring any fueling affects the new intake has on the engine.
The E38 PCM does not lock down LTFTs when going into PE. If they're too far out, AFR will be affected.
dcpatters is offline   Reply With Quote
Old 03-21-2015, 07:13 PM   #134
CreeperRS
CreeperRS's Avatar
Cool
Wanted to let everyone know that I took pictures and video, but were accidentally erased. When I restored my iPhone, since I got a new one. Luckily I do have the Dyno print outs. I'll post results shortly. My fuel trim kept steady through out every pull. We did a total of 2 pulls per intake, 4 pulls total. All with the hood closed. This was done on a MD-500 (Mustang Dyno) yesterday's outside temp at JBA was 75 degrees. Everyone was surprised at the results, especially me! I only expected at most 5hp. See for yourself...........
Old 03-21-2015, 07:37 PM   #135
CreeperRS
CreeperRS's Avatar
Cool
Old 03-21-2015, 07:42 PM   #136
CreeperRS
CreeperRS's Avatar
One thing I noticed is better throttle response, and a better sound. You can feel the difference, now I also hear a whoosh when I turn off the car. Also, I noticed specks of rubber all along the left side of the car, from the rear wheel all the way to the RF fender. After the Dyno.
Old 03-21-2015, 07:42 PM   #137
3005
3005's Avatar
Drives: 2014 Crystal Red 1LE
Nice! 16 peak HP and 10 ft-lb if I'm reading correctly? Avg numbers are up too. Been following this thread for a month waiting for your results!
3005 is offline   Reply With Quote
Old 03-21-2015, 07:43 PM   #138
staceet
Drives: 2012 camaro 2ss
so if I'm reading that right, you picked up 16 hp and 10 ft lbs with the intake? If so I'm definitely ordering one on Monday morning.
staceet is offline   Reply With Quote
Old 03-21-2015, 07:44 PM   #139
CreeperRS
CreeperRS's Avatar
Right on! You read it correctly. We were all surprised!
Old 03-21-2015, 07:48 PM   #140
CreeperRS
CreeperRS's Avatar
That's right! Cool.
