Clear Bra Installation
I'm looking for recommendations for both what type to have installed and where to go to get the work done. Most convenient would be somewhere along RTE 1 between North Attleboro and Norwood, MA. Thanks for the help.
3m and I got mine done at corvette mikes in Plymouth I no it would be a little far but he did a good job
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma. |
![]() Drives: BMW M5 Join Date: Feb 2011
I would definitely go with a film that has a clearcoat topcoat. Most films on the market don't, which is why you see lots of cars with clear bra's that don't look very good and have a yellow tinge to them. I own a detail shop in Wakefield, MA and have been installing Ventureshield film for years now with no issues. The film is extremely glossy, little to no orange peel (texture) and also has a clear topcoat which can be polished if you happen to scratch it accidentally.
I'd be happy to take care of you if Wakefield isn't too far to travel. Be careful who you choose, as there are lots of hacks out there, which can result in harm to your car. There are three important factors in a quality clear bra install. First is a proper prep of the areas being covered in film. Second is choosing a good installer. The last is choosing a good film. Here are a few jobs that I have done and have done in the past so you can see what Ventureshield looks like installed. http://www.detailingbliss.com/forum/...-clear-bra.htm http://www.detailingbliss.com/forum/...r-prep-ppf.htm http://www.detailingbliss.com/forum/...ra-install.htm |
The Hof
Drives: 2010 IOM Camaro 2SS/RS Join Date: Jan 2010
3M all the way the glossy kind.
The closest place is your garage, I did mine myself. It isn't perfect but does the job just fine for what I paid for the kit. Ken
#5 | |
3M bought out Ventureshield and owns them now, so they are the same product. The clearcoat (glossy kind) is key in case it needs to be polished down the road. I have a car at my shop right now that was improperly washed by the dealer and got pretty scratched up. So far, the Ventureshield/3M film is polishing out perfectly. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Join Date: Jul 2009
Is the adhesive on the material?
Where can I order some pieces? Do I need to cut to size? or do I need to specify what size I need to a shop? I want to put some on the Roll bar door downtubes inside the car to protect the paint finish. |
#7 | |
clear bra in MA / Boston
It is available in different size rolls from 6 inches up to 60 inches. |
#8 |
Can I order pieces from you?
I need to cover about 8' of 1 5/8" roll bar tubing. 2-4 foot X 6" pieces should do the trick. I can trim them to fit from that. Send me a PM. |
#9 |
The Hof
600 you want to do the front of your car order a kit, check out ebay dealers for one for the SS.
It isn't as straight forward as making your own window tint patterns and decals, since you taking a flat plastic and designing it over a curved surface. However if you have access to buy 3M's designs directly for your vinyl cutting machine you might be able to make your own kit. I bought mine for the whole front and hood of my camaro for under 200 on ebay and did it myself. Like I said it's not perfect, but when I took my car to get tinted the place complimented me on my job and said I only needed to learn a few tricks to make it perfect. Which I picked up by watching the guy install one on a new escalade. Ken
#10 |
obseSSed
Drives: 2010 Camaro 2SS/RS Join Date: May 2010
3M Venture Shield for sure! No one really notices it unless I point it out to them!!
I have pics of it installed here: http://www.camaro5.com/forums/album.php?albumid=5279
Proud to be COTW 12/19/11
My build thread -----> http://www.camaro5.com/forums/showthread.php?t=140034 |
#11 | |
I want to wrap the roll cage tubes where you crawl in over the tubing on each side - the door bars. They already have a couple small scratches in them. (they will be touched up once the work is done). That's why I only need a few feet. I'm covering about 8' of tubing. |
#12 |
Driver of the Blue Demon
Drives: '15 Jeep Grand Cherokee Limited Join Date: Jan 2010
clear bra...great for the everyday driver...bad for the show car driver :-P
New England Camaro 5
The Few, The Proud, The Hyper Blue Metallics DT shorties.BBK Intake.FlowMaster AT.Eibach 1'' drop.Hurst Short Throw (44% reduction).Unrestricted Motorsports Gen 1 Style Rear Spoiler.Custom Aqua Blue Metallic Interior Panels.RS Embroidered Head Rests.Interior LED by Oracle.Illuminated Bowtie by Oracle.Footwell LED by Oracle.Grille LED by Oracle.Functional Headliner Console Toggle Switches for LED Lighting.Aqua Blue Engine Cover.RotoFab Radiator Cover.Aqua Blue Fuse Box Cover from RPI Designs.Much More |
#13 | |
Drives: 2007 Jeep SRT-8 Join Date: Jun 2009
#14 |
| Where did you guys buy your 3M Clear Bra? | philipdistefano | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 17 | 03-08-2012 10:51 PM |
| Clear Bra for your new Camaro | Redlands Clear Auto Bra | Wash/Wax/Detailing and Cosmetic Maintenance Parts | 6 | 03-29-2010 09:15 PM |
| San Antonio Venrure Shield Clear Bra Installation | WhyMe | USA - Texas | 5 | 03-18-2010 11:26 AM |
| Spray on clear bra - Dominion Sure Seal Crystal Clear 2K Chip Guard | sen10l | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 03-11-2010 01:00 PM |
| Clear Bra for your Camaro | Redlands Clear Auto Bra | USA - California | 2 | 03-09-2010 04:26 PM |
