#15 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
#16 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
I coulda swore that LC holds the rpm's at 3400 or higher. cant remember off hand.
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
#17 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS,M6,Black w/CGM Stripes Join Date: Jan 2010
Only advice I can give if any is to practice and get a feel for your car. I can usually pull 1.8 60ft times off stock tires at stock air psi levels. Oh and that's not using the cars stock launch control which in my opinion sucks because all my car does is bog down when using it. I have only about 4 passes on the car so its something you gotta get the hang off. Every driver is different. My best time in a 1/8 was 8.6 so i know your car is capable of doing much more. Best of luck to you.
Sent from my DROIDX using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit. |
#18 |
Stock launch control is 4500rpms
#19 |
BAMF SS
regardless of what it is, it isn't adjustable (at least I haven't found a way to adjust it through hp tuners or anything in the owners manual). It might keep you consistant, but it won't give you the best 60'
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#20 |
I agree it doesn't give u the best and from researching I haven't seen away to adjust it
#21 | ||||
Truth Enforcer
and practice
#22 | |
BAMF SS
#23 |
In The Circle
I have a MSD 2 that I want to install. Mounting a micro switch on the clutch pedal and adjusting it after it is mounted, will be no easy feat.
#24 |
Catalyst = Catalytic converters
Spending a lot of time on the two-step is very hard on catalytic converters because all that unburned fuel ends up in the exhaust. That's bad both because of the physical shock caused by the banging and popping as the fuel finally ignites, and the dead-rich condition loading up the catalyst. |
#25 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Thanks for the translation.
#26 | |
Black cars are not hobbies, they are an obsession |
#27 |
Why the cluth pedal? Wouldn't that cause the MSD to activate when your shifting as well? Although it probably would'nt matter as far as ET.
#28 |
There, I don't know. There's still going to be a rich condition issue, but you would think that a free-flowing cat core made to OEM or better standards, mechanically speaking, would be better able to endure the physical aspect.
