1SS Victory Red Manual
Drives: 2010 1SS 6 Speed Manual Join Date: Apr 2009
RX Catch Can - Modified Mounting Bracket
I installed my catch can in a differnt location. I modified the bracket and used the bolt from the engine cover post bracket. This is a stronger mounting point than the plastic radiator, and I have no clearance issuses with any of the surrounding components or tubing, plus there's no need to trim the engine cover because the can sits much lower. I also left a little more of the factory PCV hose intact at the intake end.
1st Camaro - 77 Type LT Rally Sport, 3 Speed Manual, Inline 6 2nd - 94 Z28, 6 Speed Manual LT1 V8 3rd - 2010 1LT, 6 Speed Manual LLT V6 4th - 2010 1SS, 6 Speed Manual LS3 V8, RX Catch Can, Holley iNTECH CAI, Flowmaster Force II Exhaust Last edited by KFH; 06-26-2011 at 02:40 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Very nice! Thanks for sharing.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Good job!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
cool. I'll see if i can do the same.
Thanks, I used a spacer between the bracket and radiator. I like this better, what did you do to "modify" the bracket?
#6 |
I used a grinder to remove a section of the bracket, cutting through the original hole, and to round off the corners in order to clear the surrounding bolts and brackets, then drilled a new hole. If I were to do it again, I would remove just a little bit more from the upper end of the bracket and drill the new hole a just fraction closer to the bend. You also have to alter the angle at the bend just a little in order to clear everything.
1st Camaro - 77 Type LT Rally Sport, 3 Speed Manual, Inline 6 2nd - 94 Z28, 6 Speed Manual LT1 V8 3rd - 2010 1LT, 6 Speed Manual LLT V6 4th - 2010 1SS, 6 Speed Manual LS3 V8, RX Catch Can, Holley iNTECH CAI, Flowmaster Force II Exhaust |
#7 |
bump
#8 |
![]() Drives: 2010 CGM 2LT RS A6 Join Date: Jun 2009
Did the same thing. Works like a charm.
IO Int, 20" polished, Rx catch can, RX breather, CAI Inc, VMax TB, MRT V2
Future Mods: 3/8" Black Ice-olator, Trifecta Tune |
#9 |
Here's a picture of the amount of oil that the catch can collected after 6,000 km. I'm sure glad it's no longer going into my engine.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
That's where I mounted mine as well. I feel it is the best spot for it.
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
#11 |
Awesome, great idea.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
#12 |
The v8's mount the bracket to the engine, so I'ld say it's a good mounting location for the LLT v6.
#13 |
Cedar Creek Woodshop
That's exactly where mine is mounted
2014 Black 2SS/RS 1LE
#14 |
Catch Cans are good! Keep this crap out of my intake.
| DIY: PCV catch can install | lawdogg149 | Camaro DIY & HOW-TO instructions & discussions | 57 | 11-05-2018 04:15 PM |
| Installed Modified AAC LED side markers/turn signals | GearHeadPeter | Cosmetics and Lighting Modification Discussions | 15 | 01-20-2013 07:09 PM |
| ****CNC BILLET OIL CATCH CAN OPTIONS**** | DREV LSX | V8 Bolt-Ons & Tunes | 57 | 03-08-2012 07:46 PM |
| Radar Detector Mounting Bracket Interest | PolishMike | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 94 | 06-10-2011 05:30 PM |
| Elite Engineering catch can finally installed on my LS3 | adub4185 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 03-26-2010 10:34 AM |
