Drives: DashTronix Radar Projector Join Date: Sep 2010
Location: Display your V1 or 9500ci on your radio, DIC or HUD.
DashTronix Radar Projector! Display your V1 or 9500ci radar detector on the DIC+HUD!
Now you can display your Valentine 1™ or Escort 9500ci (custom install) radar detector in your DIC (when DIC is placed in Navigation mode), and HUD (if equipped). The HUD is not required to display your radar detector on your DIC. The Radar Projector no longer displays on the radio! Your radio is now free to display its info uninterrupted. Below is an animation of the Radar Projector in use on the DIC (in navigation mode), and HUD (if equipped). ![]() ![]() The tiny Radar Projector™ comes with everything you need right out of the box. It plugs into your car at the OBD-II port under the steering column with the included 3 foot cable cable. It automatically controls the power to the Valentine 1™, using the telephone cord that came with your Valentine 1™, by sensing when you turn your engine on and off without the need for tapping fuses, wires or using the lighter outlet. The 9500ci Radar Projector is also plug and play with the Escort 9500ci radar detector. With its incredible efficiency and intelligence it's designed to be left plugged in to your car at all times. We have a solution for users that have something already plugged into the OBD-II port. There is an additional proprietary splitter that allows two devices to be plugged into the OBD-II port at the same time, which is available at the time of purchase. That way you can use both devices simultaneously. Here are some of the exciting features of the new Camaro Radar Projector™.
situational awareness. There is simply nothing else like the Radar Projector™ available!For more information, installation instructions, or to order your Radar Projector™, visithttp://www.dashtronix.com. Units are on sale, in stock, and ready to ship! ![]() ![]() ![]() The DashTronix Radar Projector is 100% designed and built in the USA. Last edited by DashTronix; 02-21-2012 at 05:15 PM. |
![]() ![]() ![]() Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
Will this still work with the 8500 X50? I'd love to have one of these! So, these will work on 2010's without HUD perfectly fine right?
#3 | |
The Radar Projector can indeed display on the DIC on 2010 Camaro's that do not have the HUD. The Radar Projector is not compatible with the Escort 8500 x50. The Radar Projector is only compatible with the Valentine 1 radar detector and the Escort 9500ci custom install detector. Team DashTronix |
:( Looks like I'm going to have to upgrade soon! Haha. I really like that gauge projector too. That would eliminate having to find a spot for gauges and would be pretty sleeper. Thanks for the reply!
#5 | |
We will be ready for you when you need us. Be sure to check back into the website often as we are always working on new and innovative automotive products. Team DashTronix |
#6 | |
![]() ![]() ![]() ![]() Drives: 2012 45th Camaro, 2SS/M6 Join Date: Mar 2011
1. has anyone/could anyone/do you think it is feasible to have the detector mounted somewhere at the front of the bumper and just use the HUD for readouts? IMO the only benefit of your device is for safety precautions so your radar detector is not visible to the naked eye when someone looks in your car and so you don't have to pack it up every time you park. what do you know/think about the feasibility of this option? i could see this being difficult with the radar detectors in question since both have rear radar protection that would likely require dismantling the detector itself to attached to both ends of the vehicle...perhaps there is another inconspicuous place to mount that is of less trouble? 2. hooking up something in the OBD...hrmm. i'm not sure if this assumption is accurate, but won't that void the warranty? |
#7 | |
1: The Valentine 1 probably should not be mounted in the front of a car. It is not weather proof and would probably not last very long in the harsh outdoor environment. The Escort 9500ci unit does mount in the bumpers with all components hidden from view. It is a custom installed unit that has radar sensors and laser sensors that are mounted in the front and rear of the car with the main unit hidden from sight. 2: Many devices are designed to be plugged in to the OBD-II port, such as diagnostic equipment, that can be purchased off-the-shelf from designers that are not associated with GM. Team DashTronix Last edited by DashTronix; 02-22-2012 at 12:55 AM. |
#8 |
Camaro Addict
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS Join Date: Jan 2007
I have a 9500ci and mounted the display just above the DIC and below the turn signal indicators. I always have the DIC set on speed since it is impossible to read the analog speedometer on the 2010 SS. My question is can the unit be programmed to show the speed and the radar function on the same screen?
#9 |
Where???
Is dashtronx still avl? I finally bought a 9500ci and I need one any help would be awesome
#10 |
![]() Drives: 2014 chevy camaro 2lt RS Join Date: Nov 2013
they are gone , out of business as 11/14
GMG1(SW) usn ret Battleship sailor
#11 |
To bad, I was ready to go out and buy the 9500ci after seeing this set up.
My 2010 Camaro SS
COMP Cams XFI Street/Strip, Lingenfelter LS3 Heads, AHR Long tube headers + X pipe, FAST LSXR 102mm Intake manifold, LMR Cold air intake, Flowmaster 3" stainless steel exhaust, NoWeeds Exhaust cutouts, Platinum Valve spring kit, ZEX NOS system 175hp shot, Eibach Pro-Kit performance lowering springs (1" drop all around), Custom grills, bumper ports, etc.... |
#12 |
I found a company on the net selling them thank god I payed with Paypal It's been 2 months and I never got the part I had to file a claim now the website is gone
#13 |
found mine
#14 |
Where did you find one?
| The Radar / Laser MEGA thread | raqball | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 116 | 01-29-2017 12:04 AM |
| DashTronix Radar Projector! Display your V1 radar detector on the radio, DIC, + HUD! | DashTronix | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 58 | 03-12-2015 10:55 PM |
| Escort Radar 9500CI Special | unrestrictedmotorsports | Audio / Visual / Electronics/ Gauges / Nav | 1 | 08-15-2011 12:42 AM |
| DashTronix Radar Projector! Display your V1 radar detector on the radio, DIC, + HUD! | DashTronix | Audio / Visual / Electronics/ Gauges / Nav | 4 | 06-22-2011 08:55 PM |
