![]() ![]() Drives: 14 Z/28 0# Join Date: May 2013
Axle fluid change?
section 9-7 of Z/28 OM
“Because the fluid temperatures may be higher, it is necessary to change the rear axle fluid every 24 hours of racing or competitive driving.” in Z/28 special bulletin page 2 “For Z/28 track and competition driving, replace the axle fluid every 6 hours.” I’m at 6 hrs now. So which is it? both documents are here: http://www.camaro5.com/forums/showthread.php?t=323419
"PTM11" Search & Destroy
![]() Drives: 15 Z/28 Join Date: Jun 2014
I would go with the lower of the 2, would suck to take out the rear diff due to fluid breakdown.
![]() ![]() ![]() ![]() ![]() Drives: 14 1LE Join Date: Mar 2013
If you haven't changed it after the break in period I would do it now.then every 24 after.
LMS Engineering
IMO, maintenance is one of the cheap things a person can do that has no down side. I'm at 22K km's or about 12K miles and I just did my 2nd diff fluid change and it was clean and clear on the second change. I've done half a dozen AutoX days and one full track day. I can tell you when I did my first diff service I was shocked how dirty and metallic it was but I'm guessing that was from the break-in of the ring and pinion.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
#5 | |
![]() ![]() Drives: BAC Mono Join Date: Apr 2013
I already changed my Z/28 diff lube, after my first two track days. Relatively cheap and easy, although every six track hours is going to be my schedule.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
#6 |
yes I did it at 1500 miles after break in and before my track days. So the consensus is 6 hrs...correct?
#7 |
6 hrs is about 5 track days. 24 would be about 18, which come to think of it is hella long. That's like 3 years for me.! I planned on changing it once a year. Which would be after 4-5 track days and 6000 miles.
LMS Engineering
