![]() Drives: 2010 Transformer Edition Camaro Join Date: Apr 2010
Has anybody had a noise coming from the RF floorboard area at certian rpm's. It is a rattle/etching type noise. At first I thought it was the freon going threw the evaporator core, but I shut of the A/C and it was still there. It does it while driving or just bringing up the rpm's. I took it to my dealership and they ordered a 1 way valve to put in one of the heater hose. Has anybody else have this type noise and did the valve fix the noise.
![]() Drives: 2010 Camaro 2ss Join Date: Jun 2009
I have but figured it is related to exhaust or something like that ... I really have no idea what causes it. Would love to get some advice on a fix though...
There is a TSB #09-01-37-001B or Document ID#2418515 out for a gurgle or rattle type noise coming from the instrument panel/heater core/transmission area. It states that coolant flow within the heater core may be causing the noise. the fix is to install a one way valve (GM P/N 10188036) into the inlet heater hose. I will find out if it fixed my noise in a few days when the part comes in.
![]() Drives: 2010 Camaro 2SS Join Date: Mar 2010
I have this issue also, I notice if when you hear the sound and you shift to the next gear (i have the manual) the sound goes away until the RPM's get back up. Ive got 3k miles on my 2SS, the sound wasnt there for the first 1k or so. I'll check into the TSB
Automotive Designer
Drives: 2011 Camaro 2SS/RS (LS3) Join Date: Jul 2009
I have had this EXACT same issue. It drove me crazy. I ended up taking it to my local dealer, and they found that my heat shield was loose, so they adjusted it back into position and it seems to have fixed the problem.
2011 Camaro 2SS/RS LS3 (SIM/BLK)
#6 |
![]() Drives: 2013 SW 2SS/RS/1LE Join Date: May 2010
#7 | |
Took my car to the dealership today, they installed the valve. I did not hear the noise on the way home so it seems to have fixed the problem.
#8 |
nice ... I will do that too and let you know.
#9 |
![]() Drives: 2010 ABM 2SS/RSS Black Stripes Join Date: Feb 2010
Can someone give me specifics on what to tell me dealer to get this fixed? Is it the heat shield or the valve?
#10 |
![]() Drives: '10 Camaro SS/RS VR, '11 Tahoe LTZ Join Date: Aug 2009
i've noticed this in my wife's, however I cant get it to happen in mine
#11 |
Always be positive!!!
Drives: IMB 1ss/ MT Join Date: Jun 2010
does it happen when you shit from the 1st to the 4th... i drive a ss manual and i hear a wired noice when the car tells me to shift from the 1st to the 4th...
#12 |
i have the same issue. How do I fix it?
#13 |
![]() ![]() ![]() Drives: 2SS/RS ABM Camaro Join Date: Nov 2009
2SS here, and I have the same exact issue. Kind of irritating. I think I'll have the dealer look into it when it goes in for it's first oil change.
#14 |
| GM is gonna kill me!!!! | canadian ss | 5th Gen Camaro SS LS LT General Discussions | 37 | 08-09-2012 03:44 PM |
| Different noise from Dash (not the Heater Core noise) | ColdCamaroSS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 2 | 04-02-2010 10:49 AM |
| Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 12:57 PM |
| Creaking Noise - Heads up | ffrcobra_65 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 03-03-2010 03:54 PM |
| QC missed something-- AC Compressor making a whining noise under engine load | Kyle.Gilmour | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 10-09-2009 11:42 PM |
