Old 04-30-2013, 03:40 PM   #141
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by linkwpc View Post
I just did a install of 1LE parts on my 2010. Here is the thread
http://www.camaro5.com/forums/showthread.php?t=291002
Looks great! It makes it much stiffer but overall I think it improves ride quality so much.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 04-30-2013, 07:39 PM   #142
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Originally Posted by nak3dsnake View Post
Nope, the only thing that was relocated is the sway bar mount. You do not need LCA's if your not changing shocks.
I'm assuming you mean if I AM only changing shocks?? That's all I want to do it put new 1LE struts on all 4 corners.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 04-30-2013, 08:47 PM   #143
nak3dsnake
nak3dsnake's Avatar
Yes lol. Had a bit of a brain fart there...
Old 04-30-2013, 10:51 PM   #144
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Awesome! Thanks for the help man!
Old 05-07-2013, 11:15 PM   #145
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Changing to the Z style rear bar delivers a much greater improvement than changing struts and coils.
Old 07-05-2013, 01:18 AM   #146
camaro789
Drives: Camaro
Thanks to MS3DALE, I was able to get a hold of the FE6 parts numbers from the 1LE. I know some of you are eager to get your hands on them so I'm going to share. I also marked each one to show what packages also use those parts so no one orders something they already have!
Strut Tower Brace (LT, SS, 1LE) - 22756880
Front Wheel Hubs (ZL1, 1LE) (2) - 22924741
Rear Wheel Hubs (ZL1, 1LE) (2) - 22924740
Front Coil Spring (SS, 1LE) (2) - 92245257
Front Strut (1LE) (passenger side) - 22812984
Front Strut (1LE) (drivers side) - 22812985
Front Sway Bar (1LE) - 22812946
Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
Front Sway End Link (SS, ZL1, 1LE) (drivers side) - 22842516
Rear Shock Mount (1LE) (passenger side upper) - 22922446
Rear Shock Mount (1LE) (driver side upper) - 22922445
Rear Coil Spring (SS, 1LE) (2) - 92195466
Rear Shocks (1LE) (2) - 22812987
Rear Sway Bar (ZL1, 1LE) - 22786260
Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 cars for sway bar conversion)
Rear Toe Link (ZL1, 1LE) (2) - 22845487
hi bud ! my car is 2010 2LT RS, are these
must be changed ? why ? thank you
camaro789 is offline   Reply With Quote
Old 07-05-2013, 07:25 AM   #147
sycraft
COTW 5/06/2013
sycraft's Avatar
They do not "Have" to be replaced but they are better units than the regular OE, can handle increased side loads when on track.
Old 07-05-2013, 09:07 AM   #148
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
It says something very positive that the 1LE gets the good hubs as OE - durability mods like this can get pretty important in a dual-purpose road course/autocross and street-driven car.
I can get better hubs for my car, but I have to source them myself through FRPP and then do the install. Would have been really nice if it'd already been done for me at zero miles <sigh>
Norm
Norm Peterson is offline   Reply With Quote
Old 07-06-2013, 11:58 PM   #149
camaro789
Drives: Camaro
Smile
dose the whole kit direct bolt on ? any modification need ? thanks
Old 07-07-2013, 12:11 AM   #150
camaro789
Drives: Camaro
Smile
hi bud, the Front Sway Bar (1LE) - 22812946 includes the Bushings, Clamps,
dose the Rear Sway Bar (ZL1, 1LE) - 22786260 include the Bushings, Clamps too ? do they need to be ordered ? thank you again !
Old 07-07-2013, 06:04 AM   #151
sycraft
COTW 5/06/2013
sycraft's Avatar
Front and rear sways come with the clamps and bushings, as far as the "kit", its more of a order what you want type of kit. it all bolts on with no modifications and does work well. you only need the lower rear control arms if you have a 2010 or a 2011.
Old 07-07-2013, 08:00 AM   #152
camaro789
Drives: Camaro
thank you bud !
Old 07-07-2013, 08:05 AM   #153
camaro789
Drives: Camaro
Smile
hi bud after install the kit, does a wheel alignment needed ?
Old 07-07-2013, 08:29 AM   #154
sycraft
COTW 5/06/2013
sycraft's Avatar
yes
