04-27-2024, 03:48 PM | #15 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
But he did say the trans tune was locked and I wouldn't see it. So not sure if that means it was unlocked and he locked it again I figure due to trade secrets regarding trans tune dunno, but always some kind of non compete somewhere in every industry. You think maybe they just replaced the T93 TCM with one that was reprogrammed? Like on HP Tuner site? https://www.hptuners.com/product/gm-t93-tcm-services/ I assume that would explain why it is locked?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
04-27-2024, 07:21 PM | #16 | |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
04-27-2024, 08:30 PM | #17 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Now if the shop locked the tune, you might not be able to see them, but then one of the problems with this is you just have to take it on blind faith what, if anything, they tuned about your transmission... as a contrast, my car was tuned by Jannetty Racing, not exactly a noname shop (their wait times were in the multi-month range even back then), and Ted didn't hide anything from me or lock the tune. I can even look at the history and see what he changed on which day. Obviously, I do not abuse the royal treatment I received from them and try to screw them over.
2018 Camaro 2SS G7E MX0 NPP F55 IO6
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
04-27-2024, 11:37 PM | #18 | ||
04-28-2024, 11:19 AM | #19 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Hey Fluke I'm happy you got your car back and already ripping down the 1/4
Do you know what your race weight was or a close estimate? How much gas was in tank? When you stage the car do you try to stage shallow?
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
04-29-2024, 10:36 AM | #20 |
Drives: Chevy Camaro Join Date: Sep 2022
The tcm can be unlocked and you still wouldn’t see the tune in it. It’s part of how hptuners is fooling the rest of the system that the tcm is still stock. It will always show stock calibration settings when read even if the calibration is different. From the picture above it looks like only the ecm was read and not the tcm also.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
04-29-2024, 11:47 AM | #21 |
Drives: 6th gen Join Date: Aug 2013
Can you post a log file?
Based on the video looks and sounds like the trans tune is stock and likely not unlocked It should be shifting 6800 minimum.
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
04-29-2024, 05:38 PM | #22 |
Full weight for sure. Haven't done any reductions yet. About 1/2 a tank. Honestly not sure what the difference is between shallow staging and anything else. I've heard the term but don't really know what it means.
04-29-2024, 05:43 PM | #23 | |
I've seen on the old logs I made the shift points as others mentioned 6200-6500 depending on which gear it shifts from. And my power curve indicates its close to 300rpm higher than my peak. Which is close to the 500rpm the one person was talking about but rather or not another 200 rpm is going to change anything not sure. I will have to make a new log file because the software my tuner is using is version 4.11 and I did the log in 5.x so he could never view it. And I apparently already deleted the log files I made from last sunday since I have to remake them in version 4.11. Actually wait, I do have the 5.x version logs. In my email... See attached...
04-30-2024, 08:13 AM | #24 | |
I have many many hours tuning an a10 car on the street and track. according to the video shift points look dead stock there I’ll look at the logs when I get to my laptop
04-30-2024, 09:53 AM | #25 |
I would be shocked if the car wouldn’t pick up another 2mph shifting at 6600 for the 1-2 and 7k for the 2-3 and later
Unless the valve train is not up to snuff I don’t see the downside to reving it out
04-30-2024, 10:33 AM | #26 | |
Not sure about the valve train. Sent you work order info in PM
04-30-2024, 09:50 PM | #27 |
Drives: 2021 Lt1 Camaro Join Date: Apr 2022
I think the shift points need to be raised a little more and i would reduce the Tq Mgt in the shifts. I Know tuners like to play it safe with the trans but you will pick up A LOT if the Tq MGt was reduced. I just got back from the track and Picked up 4MPH and .2 in the 1/8 by reducing tq mgt and messing with injection timing.
05-01-2024, 08:46 AM | #28 |
Well either way I am probably going to the strip later today. Get some new fresh logs.
Fixed TC issue with the new front tires Will try launching from idle See if anything changes
Thread Tools | |
