03-22-2021, 07:02 AM | #29 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
There have been several write up's about the SS and 1st gear. If memory is working properly it's been proven the SS starts in 1st gear in both Drive and Sport. I know for a fact the ZL1 starts in 2nd while in Drive, and 1st while in Sport. Also with my Sedan SS with 6l80, it starts in 1st in both Drive and Sport, and doesn't auto shift while in manual mode.
03-22-2021, 07:53 AM | #30 | |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
Tap shift is not adaptive and that is why it is slower. When a 6l80/6l90 is in normal or sports mode the computer anticipates the oncoming shift and it prefills the clutch packs, when it’s in tap shift it has no way to know when the command to shift is coming so it can’t prepare for the shift. These transmissions are complicated on how they hand off from gear to gear. If you're drag racing have your tuner set it up for sport mode to shift when you want it to, and let the computer do the work, the car will be faster and more consistent.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
03-22-2021, 08:52 AM | #31 | |
03-22-2021, 08:56 AM | #32 |
Oh wow, mine doesn't do that at all!! Only if I bounce it off the limiter will it autoshift up. In first it will hold first, if I do a launch in 2nd, it will hold 2nd until I shift it. I can run it all the way to pre-redline and shift in either 1st or 2nd..
03-22-2021, 09:13 AM | #33 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Mine will only upshift on its own when its in sport mode and I don't hit the paddles.
Once I play with the paddles it only down shifts on its own. I accidently hit the paddles once going around the water box at the dragstrip and I hit the rev limiter just before the 1/8th mile and she threw out the boat anchor costing me an stock 12.9X pass. Had to settle on the 13.08 as she just didn't want to run that quick again
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
03-22-2021, 09:23 AM | #34 |
Yes, it is designed to downshift on its own, but the upshift HAS to be done by you, or that will happen, also when they downshift, it is set to only go down to 2nd, if you want 1st in manual mode, you have to select it, been that way since stock, and now tuned, but don't forget to upshift as 1st runs out real quick. lol.
03-22-2021, 10:27 AM | #35 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
It seems there are two distinct thoughts here. Some say it definitely up shifts in manual mode and others say it never does. Not sure if it’s the tuned cars that act differently. When mine was stock, it just hit the limiter and fell off, big time, no up shift. Now that I’m tuned, not sure what it would do.
03-22-2021, 10:42 AM | #36 |
Drives: 15 Camaro SS Join Date: Oct 2018
I may not be explaining it correctly, but I think yours does the same. If I approach the rev limiter using the paddles in 1st, it will automatically shift to 2nd, but only stays in 2nd for a short time and it zaps my power. It feels like a built in nanny to me. Not an issue
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
03-22-2021, 10:44 AM | #37 | |
Ryan up at GPI and explain to him whats going on. Maybe he can clear things up for us. Thanks guys for all the input and help so far!!
03-22-2021, 12:15 PM | #38 | |
Exactly, that's the thing I love about these trans. In my Sedan when in Sport mode, and you floor it coming out of a turn the DIC flashes Performance Shifting Enabled. Once it does that, the TCM just takes over and learns your driving style. Now when it shifts it hits hard, and even harder after getting it tuned. My ZL1 learns and is very badazz when it shifts up and down. It does all that rev matching even when shifting itself. I love Chevy for programing these things to run the way they do.
03-22-2021, 12:44 PM | #39 |
Ok, so I'm going to do some data logging when I can actually drive for an extended period. Insurance goes back on in the next couple weeks, so I can actually take it further than just around my home. I spoke with James @ GPI and he said that they tune the trans to be ran in "D" as the best option for say, drag racing and general driving. The manual thing will happen as I described and can not be disabled from what they said. The computer takes over in manual mode using the paddles if you dont shift before the rev limiter hits. Sucks but is what it is.
03-22-2021, 12:58 PM | #40 |
Instagram: Sangstah
For drag launches, Sport mode in auto will always be faster than the laggy paddles. I had my tuner set my trans tune so in Sport on a roll, I can set the start gear with the paddle and auto shift at redline, much better than stock.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-22-2021, 01:20 PM | #41 | |
edit; fixed the redline number from 7200 to 7400, my auto shift is 7200, redline is 7400.
03-22-2021, 01:21 PM | #42 |
Yes sir!!
Thread Tools | |
