01-11-2019, 10:41 AM | #71 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Worked on tapping/plumbing the Pro-Meth twin nozzle kit. I also have their progressive controller and stainless lines.
Pro Meth hard line twin nozzle and Camaro specific tank Close up Installed position
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
02-27-2019, 09:37 AM | #72 |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
Dan - Very nice setup! I had to come check it out after you told me the vengeance racing car wasn't yours. Keep up the good work brother! - Jeff
04-12-2019, 01:21 PM | #73 |
Dan
I just received my DSX Aux Pump system on 10 April and I must say I am impressed! The packing for shipment was top notch. The simplicity of the install is due to the level of engineering put into the kit. I was looking at another option for $799 and watched their install video. It is night and day difference with the DSX product. WELL worth the $200 difference in price. DSX will also modify your FPCM file if you send them the base file you can get from HP Tuners if you use their product. Quite a good deal.
It would take a keen eye to spot the wiring for my DSX pump in the engine bay. extremely clean. even the hoses, which are top quality BTW, are labeled on the heat sink. The hardest part of the install may be tapping the fuel tank for the fitting. Which won't be that hard. My car is a 2010 so the hardest part for me may be drilling holes to mount the pump. Later cars already have threaded holes to use - just bolt it up....service and shipping was great too.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 04-25-2019 at 10:57 AM. |
04-12-2019, 01:32 PM | #74 |
Nice project Dan, I know it is 2 years later but still thank you for your business.
Ted.
www.jannettyracing.com
04-18-2019, 04:48 AM | #75 |
Dan
Thanks Ted. It has been a long road, but work can be a killer sometimes and family always comes before that car. Could have got a lot done since 12 April, but took the family to the Italian Rivera. They loved it. I will work on the Camaro in earnest this weekend.
Dan
04-18-2019, 08:40 AM | #76 |
'It's an experiment'
Gonna love the kit!
-Don
747 RWHP 794 RWTQ
04-18-2019, 03:42 PM | #77 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Your sticking with it Dan! An inspiration to us all. Cant wait till you get that beast together so we can see what it will do!!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
04-27-2019, 07:58 AM | #78 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Nice project. Should be badass for sure.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
05-27-2019, 09:39 AM | #79 | |
Dan
She runs...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi Last edited by racesloth; 05-28-2019 at 08:58 AM. |
05-28-2019, 09:00 AM | #80 |
Dan
Fixed embed
Dan
05-28-2019, 10:15 AM | #81 |
Is the tensioner in the lower set of holes on the bracket?
05-28-2019, 11:19 AM | #82 |
Dan
Ted, it is in the upper hole - I reviewed the instructions again and it is installed per the instructions using an M10-1.5 x 120mm bolt. If I use the lower hole the threaded hole that lines up is on the supercharger and that is 3/8-16. There are no other longer bolts in that came in the kit - it would need to be 3/8-16 5.25" to work as I measure it. The diameter of the 3/8 bolt is about .02" less - how would that affect the mounting of the tensioner?
Dan
05-28-2019, 11:22 AM | #83 | |
If it was misplaced you can just pick up another one. The way it is now the belt will slip like hell.
05-30-2019, 12:50 PM | #84 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Belt routing
I thought I had the same tensioner, but i guess not. Mine pulls up while yours seems to push down. I get much more belt wrap though.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
Tags |
cam, id850, twin disc, whipple |
Thread Tools | |
